Line lock #3022344
03/09/22 02:29 PM
03/09/22 02:29 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I'm not having any luck finding the info I'm looking for anywhere else so my question is does anyone know what fittings they used to hook up their Mopar brake lines to a Hurst line lock? Is the Hurst fitting kit worthwhile for the needs?
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3022369
03/09/22 03:23 PM
03/09/22 03:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Look inside the LL ports to make sure they accept a flared tube. If so, then you need the proper flare nuts and double flaring tool. You should be able to find the nuts at Napa, etc..
Re: Line lock [Re: Stanton] #3022387
03/09/22 04:18 PM
03/09/22 04:18 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
The Hurst line lock is 1/8" NPT ports. Fitting for 3/8-24 inverted flare 3/16" tube is - Dorman 785-456D. Weatherhead 252X3. Edelmann 126320
Any auto parts store should have them.
Re: Line lock [Re: CMcAllister] #3022409
03/09/22 05:06 PM
03/09/22 05:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The only one with a male thread is the Dorman.
Re: Line lock [Re: Stanton] #3022494
03/09/22 10:07 PM
03/09/22 10:07 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
124320 Edelmann should be the correct number
Re: Line lock [Re: CMcAllister] #3023595
03/13/22 02:04 PM
03/13/22 02:04 PM
Martinsville, IN
Martinsville, IN
Thank you CMcAllister. That is exactly the info I was looking for.
I only need one of those fittings right?
One last question, we have 3/16" brake lines correct?
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3023598
03/13/22 02:08 PM
03/13/22 02:08 PM
[quo
One last question, we have 3/16" brake lines correct? [/quote] I.D. or O.D.? What year and brand car?
Re: Line lock [Re: Cab_Burge] #3023612
03/13/22 02:43 PM
03/13/22 02:43 PM
Martinsville, IN
Martinsville, IN
72 Demon. I saw just now CMcAllister had answered that in his original reply.
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3023759
03/13/22 09:48 PM
03/13/22 09:48 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends. How many lines are you going to plumb into it?
One from the MC. Then you can run individual lines from the line lock to each wheel. Or a single line with a T for the left front on the line running to the right side. Unused ports on the line lock will be plugged with a pipe plug.
Re: Line lock [Re: Cab_Burge] #3023761
03/13/22 09:50 PM
03/13/22 09:50 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Originally Posted by Cab_Burge
[quo
I.D. or O.D.? What year and brand car? [/quote]
GM uses 1/4" on the rear for some old cars. Others do different things, Race cars should use 3/16".
Re: Line lock [Re: CMcAllister] #3023783
03/13/22 10:39 PM
03/13/22 10:39 PM
Martinsville, IN
Martinsville, IN
My understanding of how these are plumbed is the rear MC port to the LL, then the LL to the proportioning valve replacing the factory line. Is this not correct?
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3024074
03/14/22 10:19 PM
03/14/22 10:19 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Probably should have asked. What is on this for brakes? All stock?
If so, the line lock should be the last thing in the system before the front brakes.
Re: Line lock [Re: CMcAllister] #3024113
03/15/22 08:39 AM
03/15/22 08:39 AM
Martinsville, IN
Martinsville, IN
1972 Demon not stock
Wilwood front brakes stock rear drums for now but will be Wilwood rear discs too.
451,727
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3024210
03/15/22 01:15 PM
03/15/22 01:15 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
451,727
Once the stock stuff comes off, the original prop valves and anything else should come off as well.
Race car? Big tires in back, littles in front? Or close to original tire sizes? OE MC or Mopar aluminum? If it's the aluminum unit, what did it come off of?
Re: Line lock [Re: CMcAllister] #3024254
03/15/22 02:53 PM
03/15/22 02:53 PM
Martinsville, IN
Martinsville, IN
Once the stock stuff comes off, the original prop valves and anything else should come off as well. And replace it with what?
Race car?
Big tires in back, littles in front? Or close to original tire sizes? 205/65R15 front
255/70R15 rears
OE MC or Mopar aluminum? If it's the aluminum unit, what did it come off of? Aluminum Mopar, don’t recall it’s about 20 years old. Whatever the popular hey get this stock one was then.
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3024421
03/15/22 10:46 PM
03/15/22 10:46 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Race car?
255/70R15 rears
Nothing. Except maybe a manual adjustable brake proportioning valve if the need is there.
Aluminum Mopar. The aluminum Mopar style MC typically used the rear port (nearest to the pushrod) as the primary port. This will be used for the brakes you want to have the highest percentage of braking. On a big rear/skinny front tire car, this will be the rear. On a street car which typically has the big brakes up front, the rear port would be the one to use for the front.
When putting big bore caliper disc brakes on a car, it is easy to get to where you need a bigger MC to provide the extra fluid. Big 4 piston calipers will need an 1 1/8" master, usually. I say usually because I've seen Wilwood kits come with small piston calipers for some reason.
Re: Line lock [Re: CMcAllister] #3024437
03/15/22 11:57 PM
03/15/22 11:57 PM
Martinsville, IN
Martinsville, IN
Race car?
255/70R15 rears
How would I not replace the proportioning valve with something? How would the brake fluid get from the MC to the line?
eBay-cdwmotorsports
Re: Line lock [Re: cdwmotorsports] #3024486
03/16/22 09:46 AM
03/16/22 09:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
For what it’s worth my 70 Duster utilizes no proportioning valve, a 15/16 aluminum master cyl which offers some pedal “feel”, the front Wilwoods are plumbed from the front port, the rear Strange brakes are plumbed from the rear. I purchased a proportioning valve to meter the fronts, but never used it. Stops just fine from 145ish mph.
Re: Line lock [Re: cdwmotorsports] #3024565
03/16/22 01:38 PM
03/16/22 01:38 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
A race/performance brake system is very straight forward. Yes you will have to make some new lines.
Master cylinder. Line from the master cylinder to tee to rear brakes. Line from master cylinder to line lock to tee to front brakes. Some folks will use the line lock as the tee, depending on where it is mounted and how they run their lines.
The MC connections depend on which end of the car you want to have the most brake bias.
Quote
Very typical. If you have four 1.75" bore 4 piston calipers on all 4 corners, you likely have a bit of a low pedal, but with a pump or two it will throw you against the belts, I don't install an adjustable valve unless it is needed for some reason. Matching caliper sizes (piston area really) with MC bore and port connections, I've never had to use one.
Mixing and matching stock stuff, disc/drum, weird MCs, is where the bandaid adjustable valve will likely be used.
Re: Line lock [Re: CMcAllister] #3024730
03/16/22 10:46 PM
03/16/22 10:46 PM
Martinsville, IN
Martinsville, IN
Quote
Thanks to you everyone involved in This thread I’ve learned way more than I figured I would. So are there problems not running a prop valve on the street? My goal is drag and drive events as well as local drag strip stuff
eBay-cdwmotorsports
