Re: Dropping in a Gen 2 Hemi?
[Re: 70VcodeCoronetRT]
#3023551
03/13/22 12:05 PM
03/13/22 12:05 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I don't see how you will get to all the header bolts dropping in from the top. I can't even see many of mine with the engine in. But I haven't ever tried it from the top.
Master, again and still
[Re: DaveRS23]
#3023572
03/13/22 12:41 PM
03/13/22 12:41 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I don't see how you will get to all the header bolts dropping in from the top. I can't even see many of mine with the engine in. But I haven't ever tried it from the top. I can access all mine from underneath. 1/4 drive and various extensions. This is B-body but E- body should not be much different. Left side is worse but doable.
[Re: NITROUSN]
#3023707
03/13/22 07:55 PM
03/13/22 07:55 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What size headers? The 2 1/4" TTIs in my Cuda hide several of the bolts on the driver's side really, really well. I have not tried to access them and hope to heck that I never have to.
[Re: DaveRS23]
#3023712
03/13/22 08:17 PM
03/13/22 08:17 PM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
Doesn't using the RB mounts interfere with some headers?
[Re: DaveRS23]
#3023714
03/13/22 08:24 PM
03/13/22 08:24 PM
NITROUSN
What size headers? The 2 1/4" TTIs in my Cuda hide several of the bolts on the driver's side really, really well. I have not tried to access them and hope to heck that I never have to. 2 1/8 TTI. Looking at the pictures it sure seems like they are able to access fairly easy.
[Re: NITROUSN]
#3023859
03/14/22 09:18 AM
03/14/22 09:18 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What size headers? The 2 1/4" TTIs in my Cuda hide several of the bolts on the driver's side really, really well. I have not tried to access them and hope to heck that I never have to. 2 1/8 TTI. Looking at the pictures it sure seems like they are able to access fairly easy. The header bolts are easy to see/access in the picture. But believe me, the tubes hug the block, almost touch the steering box, the K is in the way, and on and on. I will not say that it cannot be done, and the smaller diameter tubes would make things a bit easier. But overall, the driver's side would be a b-i-t-c-h. Like so many other things on the Hemiroids.
[Re: DaveRS23]
#3023883
03/14/22 10:40 AM
03/14/22 10:40 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I have 2-1/4 headers with my Hemi in my Challenger but with a tubular K frame and front and mid plates. I can put both headers on from underneath without lifting/removing the engine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: calrobb2000]
#3023899
03/14/22 11:07 AM
03/14/22 11:07 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
hi i have a moter plate in my 66 , more room to work .
and with that 572 cu in it would control torque much better .
i would NEVER go back . my plate sits on rubber blocks , no in car bad vibes ! that's the direction I'm headed, hope it's the right choice (sounds good).
Rich H.
Esse Quam Videri
[Re: Big-Bo-Hemoth]
#3023908
03/14/22 11:30 AM
03/14/22 11:30 AM
6PKRTSE
Motor City
I run a vacuum pump so no dipstick tube to worry about during install or removal.
