Re: Could a gear change induce wheel spin at launch?
[Re: J_BODY]
#3021690
03/07/22 10:12 PM
03/07/22 10:12 PM
Posts: 4,682 On the parachute mount
n20mstr
It depends ? IF the car has enough power , less gear will calm launches down , but 60 the same or sometimes better ….. maybe your power/converter works better with more gear ? It’s hard to say for sure , do you any data logging ? An rpm trace would show a lot here
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3021721
03/07/22 11:12 PM
03/07/22 11:12 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
The 4.30 has more wheel speed and the converter will be looser which could further cause traction problems early in the runs. Same tire and same or similar condition?
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#3021733
03/07/22 11:51 PM
03/07/22 11:51 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You can absolutely spin the tire from not enough SLR if you are not planting the tire.
That said, I find it hard to be convinced that a small step like that gear change is could make a car go from good to junk. Assuming a 3 speed, that's around a half point of gear ratio. Go back to the old set up and see.
I can tell you that running on a track that is prepped for fuel cars, along with the clutch dust and oil they leave behind, is not typically going to be the best situation for 9 and 10 second door cars.
[Re: CMcAllister]
#3021787
03/08/22 07:37 AM
03/08/22 07:37 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I think with a taller gear once you lose the tire it might be harder to get it back, but you didn't make that drastic of a change. It will be interesting to see how it does when you go back.
68 Barracuda Formula S 340
[Re: dvw]
#3021820
03/08/22 10:02 AM
03/08/22 10:02 AM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We race in a lot colder temperatures than that around here but my quickest 60 foot was 1.21 in my Daytona and 1.25 in my Duster. I also have a lot more tire than you do. Even at that when the temps did drop I had to do a longer burn out.
[Re: pittsburghracer]
#3021918
03/08/22 02:04 PM
03/08/22 02:04 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
I know a guy that's free in a couple weeks that could help at the Vegas race How old are your tires? Did you change the shocks at all to compensate? Do you have any good video of the runs? Can you email the run files?
[Re: Al_Alguire]
#3021942
03/08/22 03:00 PM
03/08/22 03:00 PM
Posts: 2,824 Connecticut
FurryStump
Connecticut
Did you heat the tire just a hair more to overcome the cooler temps? Could have made them a bit greasy.
[Re: J_BODY]
#3022070
03/08/22 08:28 PM
03/08/22 08:28 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
Do you know the difference in the density altitudes for both tracks? Did you change the jets to run Famosa ? I'm wondering if it picked up enough power due to the altitude and better air out there in the groves to make it spin the tires: work:
[Re: Dduster]
#3022529
03/10/22 12:44 AM
03/10/22 12:44 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
Slicks have 22 passes. 14psi as always Prior to this weekend I hit that test day in Vegas back in December. Was very cold that day and we loosened the front 4 clicks extension, left the rears alone. I put the turns back into the shocks prior to the 1st pass and took 2 out for pass 2. Burnouts…. yeah probably over did that perhaps…. It was “cold” Ignition….. old school 6AL timing locked at 32. Been that way forever. We went up 4 jet sizes since Vegas was the last run. Was 12.4 afr so we let it be. Starting to wish I’d stayed with my 4150 carb and 727 trans…. Fun consistent combo that definitely ran the number. I’m sure the softer barometer in Vegas might work my way.
[Re: J_BODY]
#3022720
03/10/22 07:57 PM
03/10/22 07:57 PM
Guitar Jones
I had a nostalgia pro stock racer tell me that if the track was crappy they would add more gear, not less, to reduce the wheel speed. Never tried it myself as I was locked into the one gear ratio I could get in a pro gear.
