73 Charger non AC heater plenum #3021848
03/08/22 11:12 AM
03/08/22 11:12 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
I'm restoring the heater plenum for my 73 Charger. I need to remove the Right side fresh air inlet damper. I need to drill out a few rivets.
I searched on line only to find out that there are dozens of different styles of rivets.
Anyone knows exactly what rivets I need? I have regular blind rivets tool but I'm sure that won't work.
Thanks in advance for the help.
Re: 73 Charger non AC heater plenum [Re: Gabmando] #3022055
03/08/22 08:15 PM
03/08/22 08:15 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Grind the bottom off & measure OD & length add A 1/6 or so to measured length,need to find some with the same style head old school rivet, you will never see the bottom.
for example, Ebay item# 370866624417
