No lube seals, jesel belt drive? #3020997
03/05/22 09:53 AM
03/05/22 09:53 AM
gregsdart Offline OP
Ok, i was asleep and put assembly lube on the seals of my belt drive🙄so, does it destroy the seal if run? I must think it does, since the instructions say no lobe. I am hoping to avoid pulling it back apart to clean it up, but figure odds on doing that are low. Your experiences, or info from jesel?
Re: No lube seals, jesel belt drive? [Re: gregsdart] #3021011
03/05/22 11:30 AM
03/05/22 11:30 AM
NC
440Jim Offline
440Jim  Offline
NC
Greg, I have no idea. Those are the first rubber lip seals I have used with their dry coating.
Quote
CHECK CAMSHAFT END PLAY BY SETTING A DIAL INDICATOR ON THE FACE OF THE CAM ADAPTOR AND MOVE CAM FRONT TO BACK. ADJUST THE SHIMS UNTIL THE CAMSHAFT ENDPLAY IS BETWEEN .008” AND .012”. IT IS OK TO USE ZERO SHIMS, IF CAM ENDPLAY IS CORRECT.
REMOVE THRUST PLATE AND SHIMS. APPLY A VERY THIN FILM OF RTV SEALANT BETWEEN SHIMS TO PREVENT POSSIBLE OIL LEAKAGE. REINSTALL REQUIRED SHIMS AND THRUST PLATE AND RETORQUE NUTS.
* KEEP OIL OFF SEAL AREA. * BE CAREFUL NOT TO DAMAGE SEAL ON ADAPTOR KEYWAY.
How much shim did you need to get your cam endplay?
And what timing cover gasket thickness did you use (effects end play)?
I didn't need any of the supplied shims with an 0.047" gasket. (SuperPerformance brand)
Re: No lube seals, jesel belt drive? [Re: 440Jim] #3021016
03/05/22 11:49 AM
03/05/22 11:49 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Cummins engines use a rear main seal that is similar. My buddy put a light coat of oil on his, and it leaked horribly. Put the second one in dry, and no leaks. I’d be cleaning yours.
69 GTX 68 Road Runner
Re: No lube seals, jesel belt drive? [Re: 440Jim] #3021032
03/05/22 01:11 PM
03/05/22 01:11 PM
Quote
Jim, .008 thick gasket, one . 010 shim gave . 009 play, but shims had been lubed with assembly lube.
Re: No lube seals, jesel belt drive? [Re: JERICOGTX] #3021034
03/05/22 01:14 PM
03/05/22 01:14 PM
thanks Jeff.
Re: No lube seals, jesel belt drive? [Re: gregsdart] #3021043
03/05/22 02:04 PM
03/05/22 02:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Absolutely NO LUBE on those seals!
Re: No lube seals, jesel belt drive? [Re: Al_Alguire] #3021046
03/05/22 02:22 PM
03/05/22 02:22 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
It is a Teflon seal, NO OIL per Jesel.
Re: No lube seals, jesel belt drive? [Re: Jeremiah] #3021088
03/05/22 05:41 PM
03/05/22 05:41 PM
Now the question is, can i clean the seals and surfaces, and if so, what with?
Re: No lube seals, jesel belt drive? [Re: gregsdart] #3021112
03/05/22 07:48 PM
03/05/22 07:48 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Brake cleaner should work fine & wont affect the Teflon
Re: No lube seals, jesel belt drive? [Re: gregsdart] #3021159
03/05/22 10:57 PM
03/05/22 10:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Any top shelf bourbon should work.
Re: No lube seals, jesel belt drive? [Re: gregsdart] #3021190
03/06/22 07:49 AM
03/06/22 07:49 AM
Sticky South
Rodenteliminator Offline
Sticky South
Starting Fluid / Ether is a very good cleaner if the smell doesn’t bother you or you are next to anything with a flame, it leaves a very clean and dry surface, it’s what I wipe down the surfaces with before gasket install. It will remove decal glue on paint and not damage paint etc. Doug
Sorry honey I spent the rent
Re: No lube seals, jesel belt drive? [Re: Rodenteliminator] #3021455
03/07/22 10:39 AM
03/07/22 10:39 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
"Acetone"
Re: No lube seals, jesel belt drive? [Re: RATTRAP] #3021525
03/07/22 02:40 PM
03/07/22 02:40 PM
"Acetone"
[/quote] Yeah, u-huh, it won't hurt paint either, yes sir tsk whistling
Re: No lube seals, jesel belt drive? [Re: Cab_Burge] #3021592
03/07/22 06:17 PM
03/07/22 06:17 PM
I called Jesel, and the tech said use mild dish soap and it MIGHT work. So i ordered a set od double lip teflon seals, since that was his recomendation after my saying i wanted to pull 12+ inchs of vacuum.
So all looks good, but the cost. $130 for double lip teflon seals. On the up side, i have two important items for high vacuum. DLC coated piston pins, and good seals.
