Help troubleshoot 93 w250ctd ABS light #3021048
03/05/22 02:34 PM
03/05/22 02:34 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Howdy,
My trusty 93 w250 ctd has the abs light on i changed the sensor and the light is still on. Any insight to my next move? I hace a service manual on CD but no longer have a cd player (doh).
Any insight is much appreciated.
Re: Help troubleshoot 93 w250ctd ABS light [Re: Jeremiah] #3021099
03/05/22 06:24 PM
03/05/22 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Help troubleshoot 93 w250ctd ABS light [Re: Jeremiah] #3021193
03/06/22 08:27 AM
03/06/22 08:27 AM
Guitar Jones Offline
The 93 is an RWAL system only. The module is behind the glove box and the valve is on the left frame rail near the rear axle. You can't buy any new parts for it so most guys just bypass the valve and disconnect the module.
Re: Help troubleshoot 93 w250ctd ABS light [Re: Guitar Jones] #3023864
03/14/22 09:43 AM
03/14/22 09:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It was recommended to me by a local mechanic but it's not that easy , at least not for me as the ABS light and the brake warning light are lit without the module in place. With an inop module in place the brake light is out but the ABS light flashes and that triggers a safety inspection fail. I could remove the light bulb but I'd rather have it working for now.
I'm not sure what the 93 system is like but Google it and see what comes up on other truck related forums, that is how I was able to figure out some of what I was dealing with once I got codes .
What lights are on ABS , or abs and brake ?
Read this , abs and brake light 1
it also mentions a sticky but I found nothing in it .
Also read this abs and brake light 2
