Aftermarket Guage Question? #301903
04/28/09 10:51 AM
04/28/09 10:51 AM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I have an Autometer fuel guage and matching sender combo.
I wired it up, and then with some help wires got moved etc. during a build. I am sure there was a spark or two if you catch my drift.
It did work initially.
Now it does not.
I am thinking I need a new guage. It has a good ground and a switched power etc.
Guage or sender? Which is most likely screwed up?
Thank you for any help.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: Aftermarket Guage Question? [Re: toyotajeep] #301904
04/28/09 05:35 PM
04/28/09 05:35 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
just a thought but the gauges measure resistance. Get a resistor from radioshack that works in the range of your gauge. use that to see if your gauge is reading. This will allow you to narrow down if the sending unit is sending the right information to the guage or not.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Aftermarket Guage Question? [Re: toyotajeep] #301905
04/28/09 05:59 PM
04/28/09 05:59 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Depends if you want to diagnose the problem and replace or repair the bad item or searching for a quick answer.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Aftermarket Guage Question? [Re: HealthServices] #301906
04/28/09 06:02 PM
04/28/09 06:02 PM
So Cal
So Cal
First check to see if everything is connected correctly. See the link below
Disconnect the wire to the sender it should go one way.
Ground it and it should go the other way.
This will tell you if the gauge is even taking a measurement.
Lets say you have #4714 gauge 0 ohms Empty / 90 ohms Full gauge
Basically when the wire to the sender lead is grounded it should be show empty. When the wire is not touching anything, the gauge should show full. If you can get a 40-50 ohm resistor (should be less than a couple $) the gauge should read about 1/2.
Re: Aftermarket Guage Question? [Re: HealthServices] #301907
04/28/09 06:08 PM
04/28/09 06:08 PM
Also, I'm not familiar with Autometer, but some electric gauges are what is known as a "bridge" circuit, as in, Wheatstone Bridge. What this means is that the third leg of the circuit is the gauge FRAME which must be grounded
Re: Aftermarket Guage Question? #301908
04/28/09 06:12 PM
04/28/09 06:12 PM
So Cal
So Cal
Most all autometer are three wire
Ground
positive
and sender lead.
Re: Aftermarket Guage Question? [Re: HealthServices] #301909
04/28/09 06:13 PM
04/28/09 06:13 PM
So Cal
So Cal
http://www.autometer.com/productPDF/1079A.pdf
Make sure everything is connected correctly before replacing things
Re: Aftermarket Guage Question? [Re: HealthServices] #301910
04/28/09 06:15 PM
04/28/09 06:15 PM
So Cal
So Cal
If you have a ohm meter you can bench test the sending unit too.
