thanks Doug. i thought of him right away, but thought if the original detent plate could be modified easily, i would do it myself. the bucks saved could go towards my next doctor's visit.
Re: Aftermarket auto shifter with factory linkage
[Re: dvw]
#3016765 02/19/2201:14 PM02/19/2201:14 PM
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: CSK]
#3017094 02/20/2201:08 PM02/20/2201:08 PM
[Re: randavis]
#3017152 02/20/2204:13 PM02/20/2204:13 PM
On my video I miss spoke about the stock shifter would go from neutral to reverse without pushing the button, I was wrong about that, but Y'all should get the idea.
[Re: CSK]
#3017352 02/21/2201:52 PM02/21/2201:52 PM
good video sir ! i have a good idea what's needed now to my shifter, so i have printed out several pictures and placed them in the car. i have a folder in the car listing things that need done. when they GET done, those pics and any notes related to the job at hand go into a folder in the house. there is a master index of things in the car, and if they are done, a check is placed next to them. if i need to refer back to something, or i forget if i have done something, this index helps out with a broom to part the cobwebs.
[Re: CSK]
#3017422 02/21/2205:39 PM02/21/2205:39 PM
