Re: Denso alternator, 90amp
[Re: AndyF]
#3016809
02/19/22 03:15 PM
02/19/22 03:15 PM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
Nicely designed kit Andy, but I am using a motor plate and will have to mount the alternator lower on the same side of the engine. Thanks for posting about your kit. I am mostly concerned with the quality/performance of the TSP alternators as I had never heard of them before. I saw them first in a Star Performance Parts catalog which seems geared to the circle track crowd. Thanks, Bill
[Re: lancer493]
#3017115
02/20/22 01:56 PM
02/20/22 01:56 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Not that exact p#, but I did a Denso swap a couple of years ago and I’m super happy with it. Volt guage is now locked between 12.5 and 13.8 at ALL times. I run my water pump and low speed fan after every run to get to 150 without charging between rounds and never have any issues. I looked at Andy’s kit. It looks great by the way. Ultimately, all I had to do was cut my existing adjustment bracket, lengthen the piece (find some simple flat bar that was the exact dimension of the bracket) and re-angle the bolt-slot section. Location and main bracket are unaltered. 2nd picture is the stock bracket and my template to what I made it into. Been solid for a few years now.
[Re: StealthWedge67]
#3017270
02/21/22 08:13 AM
02/21/22 08:13 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Does this solve the dreaded low voltage at idle issues for cars with accessories like EFI?
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: ChrgrCuda]
#3017321
02/21/22 12:38 PM
02/21/22 12:38 PM
Posts: 146 Missouri
randavis
Missouri
Does this solve the dreaded low voltage at idle issues for cars with accessories like EFI? I have a 60 amp Denso on my Challenger with a Sniper. It doesn't show any appreciable drop in gear at idle.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: ChrgrCuda]
#3017498
02/21/22 09:18 PM
02/21/22 09:18 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Does this solve the dreaded low voltage at idle issues for cars with accessories like EFI? Think about what these alternators are used on and it will all make sense. The average usage for a 60 amp Denso alternator is a Toyota Camry that has dual cooling fans,EFI,audio system,power windows and other accessories and they have zero issues with low voltage at idle.. I use a 60 amp Toyota pick-up alternator on my Savoy for about 9 years now and it finally quit last summer. I replaced it with a fresh Denso reman and back to charging 14.3 volts at 1100 rpm's . Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: ChrgrCuda]
#3017615
02/22/22 09:21 AM
02/22/22 09:21 AM
Posts: 16,929 NC
440Jim
NC
Does this solve the dreaded low voltage at idle issues for cars with accessories like EFI? Any post about this topic needs to state the actual pulley ratio being used and the exact idle RPM. This is such a big factor, any statement is worthless without it. 200 rpm can make a big difference (7"/2" ratio 800-1000 engine RPM).
[Re: 440Jim]
#3017637
02/22/22 10:51 AM
02/22/22 10:51 AM
Posts: 146 Missouri
randavis
Missouri
Does this solve the dreaded low voltage at idle issues for cars with accessories like EFI? Any post about this topic needs to state the actual pulley ratio being used and the exact idle RPM. This is such a big factor, any statement is worthless without it. 200 rpm can make a big difference (7"/2" ratio 800-1000 engine RPM). I am using the factory pulleys on the crank and water pump, and the standard pulley on the alt that was used on the toyota pickup.
[Re: lancer493]
#3017784
02/22/22 05:34 PM
02/22/22 05:34 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
66er, thanks, that's what I was looking for. Someone who has used this actual product and wether or not they were satisfied with it's quality. Thanks again, Bill Speedmaster does not sell or make the one you want
[Re: lancer493]
#3017935
02/23/22 08:17 AM
02/23/22 08:17 AM
ChrgrCuda
Texas, USA
Can this setup be used with a Vintage Air setup?
