Are there any automobile/truck MANUAL trans with ATF OE. #3017158
02/20/22 05:35 PM
02/20/22 05:35 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
I got into a "discussion" about automobile and truck manual transmission gear oil and someone said they use ATF and there are lots manufactures that use ATF OE. I have never heard of any manufacture's spec for ATF OE or as an alternative gear oil to use in a car or truck manual transmission. I know that some old vintage motorcycle dirt bikes used it OE but never a car or truck? I personally wouldn't use it but surprised a manufacture would recommend using it or coming in the trans OE?
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017164
02/20/22 06:16 PM
02/20/22 06:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
833od had it for a few years iirc.
Angry white pureblood male
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: ruderunner] #3017167
02/20/22 06:34 PM
02/20/22 06:34 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
All 833 trannys came with ATF from the factory. Several transfer cases use ATF such as the NP231 and NP208.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017169
02/20/22 06:37 PM
02/20/22 06:37 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I'm not big on manuals but off the top of my head, T-5's, T-56's, Mazda/Ford M50D's and Tremec's all use ATF. I used to work down the street from a transmission shop, spent more time there than I'd like to have...47RE, ugh.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017177
02/20/22 07:16 PM
02/20/22 07:16 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
My second car after high school (class of '67) was a '66 Barracuda Formula S, 4 spd. (first was a 64 Belvedere 426S, auto) This was in Vermont.
The S came to me at around 23k miles, I had no history on it. It had gear oil in the trans, and on any cold morning during the winter, the car would start, but letting the clutch out would stall the car, at high idle on the choke. Shifting was nearly impossible.
I would rev it up, let the clutch out, and have to spend about 5 minutes sitting in a 20 below car before it would idle on its own, clutch out.
This didn't last too long, I had seen a service bulletin about this, and Chrysler's answer was ATF. As soon as I could, I drained and swapped the gear lube for atf.
After that, my main complaint with the car was the fast manual steering, on Vermont's pot holed roads the kick back in the steering was a bear.
Didn't keep that car long, back then there was always something interesting coming in trade at 31 63436.
It takes gasoline to interest me.
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: moparmarks] #3017179
02/20/22 07:28 PM
02/20/22 07:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Be careful with the word "all".
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017187
02/20/22 08:50 PM
02/20/22 08:50 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
SRT-4 Neons use ATF-4. They are all 5 speed manual
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A990] #3017222
02/20/22 10:37 PM
02/20/22 10:37 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Going back a ways, Isuzu P'up/Chevy Luv trucks used Dexron in their manual transmissions. My dad bought several of the diesels with "transmission problems" caused by being filled with 80W90. One of the biggest PITA transmissions to remove that I've done in 35+ years in the business.
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: ruderunner] #3017256
02/21/22 01:51 AM
02/21/22 01:51 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Gears (like in the rear axle) require Gear Oil for optimum durability.
ATF fluids (thinner) only benefit the operation of the sync rings.
Depends on which area of operation you're most concerned with.
Ease of shifting during cold startups or long term protection of the gear train. .
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017269
02/21/22 07:47 AM
02/21/22 07:47 AM
Guitar Jones Offline
All of the Chrysler front wheel drive manual transmissions used ATF+4 from the factory. SRT also recommends ATF+4 for the NV4500 transmissions now. There are many others that use ATF.
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: A12] #3017338
02/21/22 01:10 PM
02/21/22 01:10 PM
moparx Offline
moparx  Offline
my 1984 daytona 2.2/5spd had factory ATF fill.
forgot to add, it was a front wheel drive K car.
beer
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: 3hundred] #3017353
02/21/22 01:55 PM
02/21/22 01:55 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Originally Posted by 3hundred
... Mazda/Ford M50D's...
In addition to the rear drive transmission, add to that the FWD transaxles found in the 323/Escort/Tracer/derivatives.
I think the O.P. has his answer by now...
Down to just a blue car now.
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: Guitar Jones] #3017367
02/21/22 02:29 PM
02/21/22 02:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The NVT350 (first generation Neons) are an exception. That oddball transmission used its own special gear lube.
NVT-350 lubricant
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: 6PakBee] #3017471
02/21/22 07:59 PM
02/21/22 07:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
The 4spd OD unit in my 76 RoadRunner, had ATF in it . . . when I got it rebuilt, that's what went back into it . . . and according to FSM - "DEXRON" Type Automatic Transmission Fluid . . .
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: a12rag] #3017484
02/21/22 08:48 PM
02/21/22 08:48 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Having had both manual transmissions with 80/90 gear lube and ATF, I can tell you the ATF is a lot easier to deal with in cold temps. I can also tell you the ATF can identify a seal in poor condition a lot faster then 80/90 will. I also believe the ATF lets you have noisier gear boxes on those hot long driving days then the 80/90 did, but that might be because the ATF trans has nearly 200K on it and I don't remember many 80/90 gear boxes that had much more then 120K miles on them.
I can also tell you the two lubes don't mix well, it would be good to choose one or the other, freshen the lube, and stick with your choice. Much of the "newer stuff" (mid 70s and newer) use ATF and the older stuff used 80/90. Unless your manual trans is newer then the 1990s, and you do mostly warn weather use, I would probably go with he 80/90. Newer stuff, ATF. Gene
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: poorboy] #3017512
02/21/22 09:34 PM
02/21/22 09:34 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Hi . Most Jeeps with manual tranny's also use Mopar Manual Transmission Lubricant part # 04874464AB . Same as the Pennzoil Synchromesh Fluid , very good fluid , shifts Easy in the extreme Cold . drive Ronnie
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: 1969ronnie] #3017515
02/21/22 09:38 PM
02/21/22 09:38 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf...
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: CokeBottleKid] #3017572
02/22/22 12:41 AM
02/22/22 12:41 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Well how about ATF in the rear axle of a 8-3/4?
After all; it has gears very like an a-833.
Both are reduction type setups.
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: PhillyRag] #3017855
02/22/22 09:11 PM
02/22/22 09:11 PM
Detroit, MI
Detroit, MI
confused
Re: Are there any automobile/truck MANUAL trans with ATF OE. [Re: PhillyRag] #3017884
02/22/22 10:37 PM
02/22/22 10:37 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Yeah and how about in a 2-stroke or 4-stroke motorcycle transmission that also has a wet clutch and constant mesh gears (no synchro's)? Can I use it in my Harley transmission?
