Re: Are there any automobile/truck MANUAL trans with ATF OE.
[Re: A12]
#3017164
02/20/22 06:16 PM
02/20/22 06:16 PM
Posts: 5,924 ohio
ruderunner
ohio
833od had it for a few years iirc.
Angry white pureblood male
[Re: A12]
#3017169
02/20/22 06:37 PM
02/20/22 06:37 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'm not big on manuals but off the top of my head, T-5's, T-56's, Mazda/Ford M50D's and Tremec's all use ATF. I used to work down the street from a transmission shop, spent more time there than I'd like to have...47RE, ugh.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: A12]
#3017177
02/20/22 07:16 PM
02/20/22 07:16 PM
Posts: 1,357 central Florida
VL21
central Florida
My second car after high school (class of '67) was a '66 Barracuda Formula S, 4 spd. (first was a 64 Belvedere 426S, auto) This was in Vermont.
The S came to me at around 23k miles, I had no history on it. It had gear oil in the trans, and on any cold morning during the winter, the car would start, but letting the clutch out would stall the car, at high idle on the choke. Shifting was nearly impossible.
I would rev it up, let the clutch out, and have to spend about 5 minutes sitting in a 20 below car before it would idle on its own, clutch out.
This didn't last too long, I had seen a service bulletin about this, and Chrysler's answer was ATF. As soon as I could, I drained and swapped the gear lube for atf.
After that, my main complaint with the car was the fast manual steering, on Vermont's pot holed roads the kick back in the steering was a bear.
Didn't keep that car long, back then there was always something interesting coming in trade at 31 63436.
It takes gasoline to interest me.
[Re: moparmarks]
#3017179
02/20/22 07:28 PM
02/20/22 07:28 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 833 trannys came with ATF from the factory. Be careful with the word "all".
[Re: ruderunner]
#3017256
02/21/22 01:51 AM
02/21/22 01:51 AM
Posts: 1,757 Phila
PhillyRag
Phila
833od had it for a few years iirc. Gears (like in the rear axle) require Gear Oil for optimum durability. ATF fluids (thinner) only benefit the operation of the sync rings. Depends on which area of operation you're most concerned with. Ease of shifting during cold startups or long term protection of the gear train. .
[Re: A12]
#3017269
02/21/22 07:47 AM
02/21/22 07:47 AM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
All of the Chrysler front wheel drive manual transmissions used ATF+4 from the factory. SRT also recommends ATF+4 for the NV4500 transmissions now. There are many others that use ATF.
[Re: A12]
#3017338
02/21/22 01:10 PM
02/21/22 01:10 PM
Posts: 19,587 north of coder
moparx
my 1984 daytona 2.2/5spd had factory ATF fill. forgot to add, it was a front wheel drive K car.
[Re: 3hundred]
#3017353
02/21/22 01:55 PM
02/21/22 01:55 PM
Posts: 9,312 SoCal
68HemiB
SoCal
In addition to the rear drive transmission, add to that the FWD transaxles found in the 323/Escort/Tracer/derivatives. I think the O.P. has his answer by now...
Down to just a blue car now.
[Re: Guitar Jones]
#3017367
02/21/22 02:29 PM
02/21/22 02:29 PM
Posts: 10,752 North Dakota
6PakBee
North Dakota
All of the Chrysler front wheel drive manual transmissions used ATF+4 from the factory. SRT also recommends ATF+4 for the NV4500 transmissions now. There are many others that use ATF. The NVT350 (first generation Neons) are an exception. That oddball transmission used its own special gear lube. NVT-350 lubricant
[Re: 6PakBee]
#3017471
02/21/22 07:59 PM
02/21/22 07:59 PM
Posts: 2,922 Calgary, Alberta Canada
a12rag
The 4spd OD unit in my 76 RoadRunner, had ATF in it . . . when I got it rebuilt, that's what went back into it . . . and according to FSM - "DEXRON" Type Automatic Transmission Fluid . . .
[Re: a12rag]
#3017484
02/21/22 08:48 PM
02/21/22 08:48 PM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
Having had both manual transmissions with 80/90 gear lube and ATF, I can tell you the ATF is a lot easier to deal with in cold temps. I can also tell you the ATF can identify a seal in poor condition a lot faster then 80/90 will. I also believe the ATF lets you have noisier gear boxes on those hot long driving days then the 80/90 did, but that might be because the ATF trans has nearly 200K on it and I don't remember many 80/90 gear boxes that had much more then 120K miles on them.
I can also tell you the two lubes don't mix well, it would be good to choose one or the other, freshen the lube, and stick with your choice. Much of the "newer stuff" (mid 70s and newer) use ATF and the older stuff used 80/90. Unless your manual trans is newer then the 1990s, and you do mostly warn weather use, I would probably go with he 80/90. Newer stuff, ATF. Gene
[Re: 1969ronnie]
#3017515
02/21/22 09:38 PM
02/21/22 09:38 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf...
[Re: CokeBottleKid]
#3017572
02/22/22 12:41 AM
02/22/22 12:41 AM
Posts: 1,757 Phila
PhillyRag
Phila
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf... Well how about ATF in the rear axle of a 8-3/4? After all; it has gears very like an a-833. Both are reduction type setups.
[Re: PhillyRag]
#3017884
02/22/22 10:37 PM
02/22/22 10:37 PM
Posts: 21,533 N.E. OHIO, USA
A12
N.E. OHIO, USA
I mean... have you had your head in a hole in the ground :P? I think at this point most manwells use ATF, every tremec has since the T5, so every modern muscle car with a 6 speed uses atf... Well how about ATF in the rear axle of a 8-3/4? After all; it has gears very like an a-833. Both are reduction type setups. Yeah and how about in a 2-stroke or 4-stroke motorcycle transmission that also has a wet clutch and constant mesh gears (no synchro's)? Can I use it in my Harley transmission?
