Mechanical Diode Converter? #3016907
02/19/22 07:42 PM
02/19/22 07:42 PM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
Just had a local guy rebuild my 727 to go behind my 99% street driven 440 With 520hp and 535 ftlbs as per the dyno.
He wants to sell me a converter he has. 245mm with billet back cover, furnace brazed with mechanical diode, low stall stator.
To be honest whats required in a performance converter is getting me a bit lost. I have read up on the mechanical diode as that was new to me. Sonnax does not recommend them for street use however.
Prior to this I did email SMR Transmission and as per my cam he recommended a 3000rpm stall but nothing near as exotic.
Re: Mechanical Diode Converter? [Re: PossessedDuster] #3017660
02/22/22 12:02 PM
02/22/22 12:02 PM
an8sec70cuda Offline
The mechanical diode is a REALLY strong sprag. They are perfectly streetable and expensive. At your power level, it is overkill.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mechanical Diode Converter? [Re: PossessedDuster] #3017663
02/22/22 12:12 PM
02/22/22 12:12 PM
Minn
SportF Offline
SportF  Offline
Minn
I get a kick out of calling it a "mechanical diode". Its a frecking rachet instead of a bearing clutch.
Re: Mechanical Diode Converter? [Re: SportF] #3017671
02/22/22 01:05 PM
02/22/22 01:05 PM
Your correct, I have one that was remove form oe of my old race converters after blowing it up due to a massive fin failure whiney
