Re: Aftermarket auto shifter with factory linkage
[Re: stumpy]
#2498240
05/20/18 02:25 PM
05/20/18 02:25 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
I would think the biggest issue would be getting the ratio between the shifter stroke and the shift lever movement correct. I agree, might take some measuring and trial and error but you have to do that with a cable also. The cable uses those jam nuts and the little clevis on the end.
'71 Duster '17 Ram 1500
[Re: RMCHRGR]
#2498676
05/21/18 04:13 PM
05/21/18 04:13 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
No help here but I will be watching this thread. Very good idea. I hate screwing around with the cable and have replaced several over the years. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: RMCHRGR]
#3015833
02/15/22 10:24 PM
02/15/22 10:24 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
I would think the biggest issue would be getting the ratio between the shifter stroke and the shift lever movement correct. I agree, might take some measuring and trial and error but you have to do that with a cable also. The cable uses those jam nuts and the little clevis on the end. Stumpy is correct on the lever ratio. Adjusting the cable nuts only aligns the cable to the trans, it does not affect the lever ratio. using the posted pic as a guide, one might be able to fabe a plate and attach with small vise grips until the correct ration is found. The tack weld it into place, recheck and finish welding. No welder??? once on place carefully drill one small hole, install snug fitting screw & nut. Recheck. if good drill a second hole.
[Re: SNK-EYZ]
#3015901
02/16/22 08:16 AM
02/16/22 08:16 AM
Posts: 9,835 MI, usa
dvw
MI, usa
I did it in my Volare years ago. Still works great going 30 years now. I cut an old melted cable short. Its attached to the B&M shifter. Then to the bell crank that comes thru the floor. I used the B&M lever and pivot that would've attached at the trans. Vice gripped that piece to the factory floor bell crank. Moved it in and out from the pivot point of the bell crank until the ratio was correct. Then welded the 2 together. Doug
[Re: CSK]
#3016251
02/17/22 11:08 AM
02/17/22 11:08 AM
Posts: 782 Minnesota
skep419
Minnesota
I converted my stock shifter to a cable in my 68 Charger, works great That seems like the worst of both worlds to me The reason to ditch the stock shifter is to not accidently shift into neutral. The reason the ratchet shifter sucks is because of the crappy cable and the routing needed to keep it from being melted. Having a ratchet shifter mated to the factory linkage would be the best of both worlds in my opinion. No missed shifts and no stupid cable.
[Re: skep419]
#3016254
02/17/22 11:15 AM
02/17/22 11:15 AM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
I converted my stock shifter to a cable in my 68 Charger, works great That seems like the worst of both worlds to me The reason to ditch the stock shifter is to not accidently shift into neutral. The reason the ratchet shifter sucks is because of the crappy cable and the routing needed to keep it from being melted. Having a ratchet shifter mated to the factory linkage would be the best of both worlds in my opinion. No missed shifts and no stupid cable. I modified the detents on the shifter, it works positive stops for shifting, it works awesome. sifting from 1st to 2nd push the handle forward, it locks in second, push the button on top of shifter handle holding it down shift to 3rd it locks in third, let go of the button & shift to neutral & it wont go anyfurther until you push the button again
[Re: CSK]
#3016257
02/17/22 11:41 AM
02/17/22 11:41 AM
skep419
Minnesota
[Re: skep419]
#3016284
02/17/22 01:09 PM
02/17/22 01:09 PM
CSK
Pattison Texas
Yes, I just did it to my stock one, welded & cutting ,grinding
[Re: CSK]
#3016287
02/17/22 01:14 PM
02/17/22 01:14 PM
CSK
Pattison Texas
The cable mounting has been made different than in the picture, this was a mock up & the detent plate was more refined. its a manual shift valve body, & has over 12k miles on it, LOTS of use & all is still good
