Re: 1938 coupe need help
#301585
05/01/09 12:22 AM
05/01/09 12:22 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
welded drivshaft in the middle, YES that is your vibration some people should learn how to do things right, not just do whatever they think might work good luck on the new engine purchase what are your plans for the frontend and brakes? hope you dont get discouraged with your project, there are some good guys here that will help you through the issues the last owner made for you. just ask and we will try to keep things moving for you Ron....
[Re: bigdad]
#301587
05/05/09 10:27 PM
05/05/09 10:27 PM
#301588
05/05/09 10:44 PM
05/05/09 10:44 PM
have a questions on set up of the steering system. I would prefer to find a good donor car/truck for the rack and steering colum but was wondering if any one had any advice. I removed the current steering colum from the car and want to start hunting down the other times. I am going to keep the 5 in drop with the disc brake set up that is currently on the car. Also question on the steering colum and the exhaust on the drivers side. what options do I have for the exhaust etc. I am still waiting on the engine so am unable to mock everything up to see what and how much room I have. I konw there wont bee much.
#301589
05/05/09 11:28 PM
05/05/09 11:28 PM
Mopar Ron
I have to admit that I have not done to much with tube axles in about 20 years, all the vehicles I have built have had independent front ends. so most of my knowledge on axles is pretty old, but having the rack mounted to the axle was a big no no. as the axle moves up and down the steering shaft would have to have some kind of movement or things will bind or break. I would look at the way the front springs are mounted to make sure that the axle is not moving around to much. I would go with something like a vega box and go with a cross steer setup like this:
#301591
05/06/09 11:23 PM
05/06/09 11:23 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
That's a heckuva cool lookin coupe project! I would take a long hard look at the front end, unless you want to keep it badly for the LOOK, there are quite a few drawbacks... the rack with the straight front axle I've never seen to be honest. I love the shape of the car. Keep on posting, and welcome to MoParts!
CrAzYMoPaRGuY
[Re: moparx]
#301593
05/07/09 08:47 PM
05/07/09 08:47 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I used the original straight axle, disc brake kit from Plydo. Mono leaf springs from Butch's Rod Shop. I also have rack and pinion but is not attached to the axle, the unit is from Unisteer. I had a bracket made to adapt to the Mopar frame. It still drives like a straight axle but I have no problems with the set up.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: moparx]
#301596
05/07/09 09:28 PM
05/07/09 09:28 PM
Mopar Ron
ron, just out of curiosity, have you ever seen one of these ? would it be possible to take a common M2 rack & remove the dr. side inner tyerod assembly then fab an extender[for lack of a better word] for the pass. side rod assembly ? of course the whole deal would have to have a custom mount fabbed.
no i haven't seen one in person but I had the same thoughts Ron...
[Re: Mopar Ron]
#301597
05/07/09 09:58 PM
05/07/09 09:58 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Thinking out loud here. Why couldn't a guy take a Cavilere rack and mount it to the frame, then run the tie rod (for better lack of the correct term) from the center of the rack to the right side only then set the rest up like a standard cross steer setup? The center mount inner rod connections would make for a longer rod then a MII that comes out the end. A guy could set the rack more to the left side to better match up with the column and a longer right side "tie rod" ran to to reduce the bump steer even more. Wouldn't think it would make a difference to the rack if it only ran a tie rod to one side and nothing to the other side. Now, someone tell me how bad my mind is working tonight so I don't go out and do something stupid. Gene
[Re: Mopar Ron]
#301599
05/21/09 10:30 PM
05/21/09 10:30 PM
Does anyone sell full kit that I can purchase to set up the steering? Or do I have to piece each items together? I would like to kep the drop axle in the front I like how it or do I need to go with a mustang II front end etc. does anyone have a set up that they would sell??? let me konw
#301600
05/22/09 08:46 AM
05/22/09 08:46 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
flaming river may have every thing you need, just wont be in aa package,,marked for a specific year,, but they may be able to help you or call fat man fab in mint hill n carolna
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
