Brake hose needed #3015375
02/14/22 02:34 PM
02/14/22 02:34 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
So I got a Mustang II style suspension on my '34 plymouth and then got bigger discs which I am pretty sure are GM. Anyway, the hose has a banjo on one end, and a "bubble" fitting on the other. I need a hose about 18" long with a banjo on one end and the 3/8 flare on the other. A '75 Fury has a 15" hose with (I think) 3/8 flare on the other. That is short. Anybody know of a hose that will work here. I have spent hours on Rock Auto, but no sure hits.
BTW, I didn't even know there was such thing as a Bubble fitting till this. I guess I should work on newer stuff more often. Well, maybe not.
Re: Brake hose needed [Re: SportF] #3015497
02/14/22 08:31 PM
02/14/22 08:31 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
This any help ? link
Re: Brake hose needed [Re: Old Ray] #3015510
02/14/22 08:47 PM
02/14/22 08:47 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
YES!!! Just ordered it. Thanks. I guess I got stuck trying to find stock stuff. Woo hooo!
Re: Brake hose needed [Re: SportF] #3015661
02/15/22 02:13 PM
02/15/22 02:13 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
Re: Brake hose needed [Re: dart4forte] #3107972
01/03/23 12:24 PM
01/03/23 12:24 PM
Green Bay
Andyvh1959 Offline
Andyvh1959  Offline
Green Bay
On a custom build, I would not waste any money on OEM brake hoses. In general, OEM brake hsoes are the least needed to meet the SAE specs, least cost always precedes best product for the application. Best hose for brakes are Teflon tube stainless steel braid hoses. Many people think the S/S is what makes these hoses good, but for brake fluid its the Teflon tube that is most important. Teflon tube does not, can not, degrade over time and is the most durable against any type of brake fluid. The variety of hose ends available means any decent hydraulic hose distributor can make custom hoses for you. A Parker Store is the retail outlet for Parker hydraulic hose. Not cheap, but very good.
Some people say you cannot use teflon tube stainless steel hydraulic hose for brake systems. Yes you can. The SAE requirements for brake hose are mostly for fluid compatibility, labeling (printed on the hose) and some brake hoses tests (hose whip test, hose end pulloff test, temperature test). The only SAE spec a standard S/S braided hydraulic hose cannot meet is the requirement for DOT labeling on the hose itself. If you want all the specs then buy S/S braid hoses from a supplier like Earls or Russel which will have the DOT labeling on the hose (on a cover over the S/S). Otherwise a S/S braid hydraulic hose will do it all, just without the DOT labeling.
My 56 C3-B8 Dakota build
