indy roller rocker failure #3015232
02/14/22 03:11 AM
02/14/22 03:11 AM
wi
Furys Offline OP
Furys  Offline OP
wi
we purchased a 426 hemi car,ran good till one day a hell of a noise,shut it down,pulled valve cover found a roller rocker broken,pin and roller came out,also noticed the intake rockers which are indy were not lined up with the valve stem,did some forget to shim these???are the stands on backwards???have no idea,need some help,here are some pics
273569945_1152102528938242_4072415402194338551_n (1).jpg273521286_1788519204673430_2823686476759095839_n (1).jpg273528772_978662613035595_1484863272792923708_n (1).jpg273600776_274714591400724_9099535755599872552_n (1).jpg
Re: indy roller rocker failure [Re: 11secdart] #3015277
02/14/22 09:58 AM
02/14/22 09:58 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
You can't compare the Indy/Dove aluminum rockers with the Indy Chromoly Hemi rockers. twocents
Whoever did the engine, did a piss poor assembly job from looking at the few photos. I would double check that all the stands are of the same heights, etc. The rockers definitely weren't set up correctly.
Re: indy roller rocker failure [Re: sixpakdodge] #3015302
02/14/22 11:09 AM
02/14/22 11:09 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Can’t really blame the rocker for failing on that one.
Re: indy roller rocker failure [Re: Furys] #3015311
02/14/22 11:43 AM
02/14/22 11:43 AM
AndyF Online content
AndyF  Online Content
Whoever put the valvetrain together wasn't paying attention. Better pull the whole engine apart and check everything.
Re: indy roller rocker failure [Re: AndyF] #3015315
02/14/22 11:52 AM
02/14/22 11:52 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Agreed. Thread should be titled "engine builder failure"
Re: indy roller rocker failure [Re: AndyF] #3015334
02/14/22 01:03 PM
02/14/22 01:03 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That is putting it very mildly laugh2
Re: indy roller rocker failure [Re: INTMD8] #3015337
02/14/22 01:10 PM
02/14/22 01:10 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yes I agree it needs to come out. Your rocker tip alignment is whack. MOST likely due to a pushrod rubbing problem that is common to those rockers. Instead of grinding for clearance they just moved the tip halfway off the valve. You need lash caps as well from the looks of it, again fairly common on hemi engines. From the looks of it you most likely got lucky that it did not drop a valve. Todd
Re: indy roller rocker failure [Re: Furys] #3015343
02/14/22 01:24 PM
02/14/22 01:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Dodged a bullet, could have been much, much worse.
Who knows what else is messed up?
Tear the whole thing down and start over.
Rich H.
Esse Quam Videri
Re: indy roller rocker failure [Re: sasquatch] #3015344
02/14/22 01:24 PM
02/14/22 01:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree with this and all statments made prior...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: indy roller rocker failure [Re: Furys] #3015352
02/14/22 01:40 PM
02/14/22 01:40 PM
There was a GTO with a fresh rebuilt 400 at the shop the other day. Owner was complaining about the engine making noise. Turns out the engine builder installed the wrong spark plugs (3/4 reach rather than 3/8 reach) and the tips of the plugs had hit the valves. The valves got dinged up, the pushrods got bent, the cam got wiped out and the whole motor needed to be torn down and rebuilt since it was full of cast iron dust. Moral of the story is that all it takes is one small thing to be wrong and an engine will start to self destruct.
Re: indy roller rocker failure [Re: W.I.N. Racing] #3017192
02/20/22 09:13 PM
02/20/22 09:13 PM
wi
Furys Offline OP
Furys  Offline OP
wi
has lash caps,took aprt,getting some stage v rockers and stands,redoing it all,thanx
Re: indy roller rocker failure [Re: ZIPPY] #3017204
02/20/22 10:00 PM
02/20/22 10:00 PM
iagree scope
You may be able to shim the rocker arms to correct the misalignment on them scope wrench
Another reason I call them motors Hemiroids whistling shruggy
