what plugs (reach) for EQ heads #3015319
02/14/22 12:04 PM
02/14/22 12:04 PM
RapidRobert Offline OP
new zealand iron heads. champion rn12yc & autolite 3924/5224 are too short & autolite 5325 are too long. thank you for your time. RR
Re: what plugs (reach) for EQ heads [Re: RapidRobert] #3015374
02/14/22 02:32 PM
02/14/22 02:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If design intent is 3/4" reach, which I think most of us would probably agree on as a 5.2/5.9 magnum head, I believe
I would not want to stick future users of the engine with an oddball spark plug, and I would want to correct the machining error
by spotfacing the spark plug hole to the proper depth in order to use the intended spark plug.
Rich H.
Esse Quam Videri
