Re: Aftermarket wiring kits, best one for 70's truck?
[Re: migsBIG]
#3015298
02/14/22 11:04 AM
02/14/22 11:04 AM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
I think we need to start leaning on M&H / YearOne to manufacture harnesses for our trucks. There is not a single clip, pin, or connector type found on the Tin Grille trucks that is NOT found on any of the muscle car harnesses that M&H already manufacturers.
Having said that, there really isn't a replacement option. I went as far as pulling all the harness off a donor that was a 74 W200, layed them out on the kitchen table, un-wrapped all the sheathing, cleaned every single terminal, tested continuity of every circuit, greased all the connections, and re-insulated the entire harness and installed it. Every single thing works.
There are some things that should be done like the Ammeter bypass, adding a relay to power the headlights, horns, and blower motor when it's on high speed.
When it comes to LED lights, I'm VERY happy with the bulbs I've purchased from SuperBrightLED's...they cost a little more, but the service is great and they only select quality bulbs to sell on their site. I've purchased the whatever is fairly cheap with a brand name I can't pronounce from Amazon and it's been hit or miss for me. But every bulb in the Ramcharger is now an LED.
Another thing to keep in mind with the dash lights, is that most LED bulbs are polarity specific, so test them as you install them with the cluster out to make it easier to quickly flip the bulb in the socket.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: migsBIG]
#3015840
02/15/22 10:58 PM
02/15/22 10:58 PM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Since the harness on my 75' is coming on 50 years and would probably like to upgrade the dash gauges and lights to LED's, so looking for a full harness that would work nice in the truck. suggestion please. That is a simple wiring system on that truck. I would pull it and inspect it. It can be cleaned up and repaired along with upgrades added. I would install a sub fuse panel for the upgrades.
[Re: mgoblue9798]
#3017815
02/22/22 07:36 PM
02/22/22 07:36 PM
Posts: 2,231 ILLINOIS
volaredon
ILLINOIS
none. Because your vehicle says Dodge on the hood not Shivvy. Been there my head is spinning, I ended up getting a harness from a junkyard donor and untaping that and going thru it to be sure it's in good shape. The harness that was original to mt 85 D150 was THE WORST engine wiring harness I have EVER seen, for butchery. NPD don't even acknowledge there is such a thing as Dodge trucks. LMC barely does. Brothers truck parts, the list goes on. Im so sick n tired of the aftermarket, having never owned anything besides a Dodge. Junkyards, swap meets, Ebay, your fellow forum members, and the occasional drive around the country and knock on someone's door, to ask what they are gonna do with that old truck that you've noticed that's sat for a while. Or restore/rebuild the parts yourself.
[Re: migsBIG]
#3031456
04/07/22 02:17 AM
04/07/22 02:17 AM
Posts: 4,145 Canada -- Posts: 4034 -Registe...
5thAve
Id rather have an old wiring harness where you can see it's been properly repaired as needed over something that's all new that someone has done who knows what to it. That's the sort of thing that makes a lot of people run when they're looking at used vehicles unless they know there are new harnesses available. Unless the whole thing is burnt up cut up melted junk.
[Re: 5thAve]
#3031949
04/08/22 06:28 PM
04/08/22 06:28 PM
volaredon
ILLINOIS
yup. My 85 D150 came to me with the most butchered wiring harness I have ever seen. It was less work to go get a harness off a junkyard truck, sprawl it all out on the kitchen table, unwrap it completely and go thru IT to make sure allw as OK, and fix the few small areas that had deteriorated from age then rewrap it and put it onto the truck, than it would have been to try and make heads or tails out of the original one.
This was just a start but the main "HOT" from the alternator was spliced, changed color and gauge 3 times in the length of a slant 6 valve cover. and the worst of those was just stripped, twisted and (poorly) taped, dangling directly over the steel fuel line that drapes over the valve cover and goes from fuel pump to carb. IDK how there was even a truck left there, for me to even have a chance to buy// how it hadn't burnt to a crisp long before. So yes it heavily depends on who is working on the harness, and the methods used to do any modifications/repairs. I completely trust my ways of working on a wiring harness!!!!! but certainly not the P.O.'s.... I have seen some pretty bad wiring butchery over the years here and there but nowhere near the amount of butchery all bundled (and bungled) in one vehicle!!!
