New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles #3014678
02/12/22 01:03 PM
02/12/22 01:03 PM
Polson, MT
DoctorDiff Offline OP
Polson, MT
https://www.doctordiff.com/axle-pkg-7-1-4-mopar-5x4-1-2-bolt-pattern-pair.html
This is an industry first.
DoctorDiff 5 x 4.5" bolt pattern conversion axles fit '62-'72 A-body 7.25" rearends. Must use open ended 1/2"-20 lug nuts.
Will NOT fit '73-'76 A-body 7.25" rears.
New 5 x 4.5" bolt pattern 7.25" 9" and 10" drums are also available.
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: DoctorDiff] #3014776
02/12/22 07:16 PM
02/12/22 07:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is awesome Cass! up Can you tell me what the differences are in the late 7-1/4"? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: Rhinodart] #3014815
02/12/22 08:42 PM
02/12/22 08:42 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
73-76 7.25 with BBP has a larger wheel bearing on it Jim. The spacing for the brake is also different.
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: slantzilla] #3014822
02/12/22 09:01 PM
02/12/22 09:01 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I assume Dr Diff's new LBP axles would use the normal 4.5" pattern brakes so they ought to have the same spacing as the 73-76 axles do.
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: Sniper] #3014971
02/13/22 11:32 AM
02/13/22 11:32 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
So, can the 73 and up 7.25 10” brake drums and backing plates be used on a 8.75?
Abe Lincoln
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: dart4forte] #3015127
02/13/22 07:47 PM
02/13/22 07:47 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes, I've done it multiple times. boogie
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: dart4forte] #3015320
02/14/22 12:12 PM
02/14/22 12:12 PM
Polson, MT
Polson, MT
''73 and newer 5 x 4.5" bolt pattern brakes taken from a 7.25" rear will interchange onto a 5 x 4.5" bolt pattern 8.75" rear.
My new 5 x 4.5" bolt pattern 7.25" conversion axles use stock '72 and earlier 9" or 10" A-body drum brake hardware and backing plates. You must re-drill the brake drums or purchase my new 5 x 4.5" bolt pattern drums.
Re: New Product - '62-'72 A-Body 5 x 4.5" pattern 7.25" axles [Re: DoctorDiff] #3016353
02/17/22 06:09 PM
02/17/22 06:09 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
As always, you DA MAN Cass! up
A-Body's RULE!
