727 Trans. Pan Question #3014033
02/10/22 01:58 PM
02/10/22 01:58 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'm going to be converting my 4-spd. car to a 727 automatic and have a question about trans. pans. What I would like to know is whether or not it is a good investment to purchase an extra capacity deep pan for a street driven only car or is a standard factory pan sufficient? I won't be doing any racing so that is not a factor. Engine is a stock stroke 340 and the rear has 3:55 gears.
Re: 727 Trans. Pan Question [Re: 440mopar] #3014036
02/10/22 02:10 PM
02/10/22 02:10 PM
Kirkland, Washington
Pacnorthcuda Offline
Stock pan will be fine for that application.
Re: 727 Trans. Pan Question [Re: Pacnorthcuda] #3014049
02/10/22 02:40 PM
02/10/22 02:40 PM
moparx Offline
moparx  Offline
if it were me, i would use an A518 pan.
that one is just a touch deeper, holding maybe two quart more, is easy to find, and WAY less expensive than deep aluminum pans.
whatever you decide, install a magnet in the pan. those are more effective than the magnetic drain plugs.
just my opinion. your mileage will vary.
beer
Re: 727 Trans. Pan Question [Re: moparx] #3014065
02/10/22 04:06 PM
02/10/22 04:06 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You won’t regret doing a deep pan
I want my fair share
Re: 727 Trans. Pan Question [Re: 440mopar] #3014075
02/10/22 04:31 PM
02/10/22 04:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
I wouldn't hesitate now to use a stock pan in your deal up
I installed a tranny temperature gauge in my last street and strip pump gas car that I beat on the street and track with 10. inch high stall converter and later put a 9.0 inch T/A SS Hemi converter in the car with no other changes, the tranny temps never got above 220 F at the track when going rounds or on the street in the summer.
The motor made over 700 HP and more torque than HP, 3450 lbs. with me in it and it ran 10.00 at 134.+ MPH in the 1/4 mile boogie
The tranny temp on the street were usually below 160 F, NOT GOOD down
ATF needs to be at least 160 F or above for some of the additives in them to start working properly scope
Re: 727 Trans. Pan Question [Re: Cab_Burge] #3014098
02/10/22 05:23 PM
02/10/22 05:23 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I think if you go with the 518 pan you may need a filter extender plate. But I could be mistaken.
Re: 727 Trans. Pan Question [Re: stumpy] #3014100
02/10/22 05:27 PM
02/10/22 05:27 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Originally Posted by stumpy
I think if you go with the 518 pan you need a filter extender plate.
You can still run it with the stock filter. The fluid level doesn't change.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 727 Trans. Pan Question [Re: Prodart440] #3014102
02/10/22 05:32 PM
02/10/22 05:32 PM
Grand Prairie,Texas
Grand Prairie,Texas
Re: 727 Trans. Pan Question [Re: stumpy] #3014106
02/10/22 05:39 PM
02/10/22 05:39 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Or since the pan is off, run the later model plastic filter.
Aaron
68 Coronet 440
Re: 727 Trans. Pan Question [Re: Prodart440] #3014124
02/10/22 06:48 PM
02/10/22 06:48 PM
BDW Offline
BDW  Offline
That's what I'm doing. You can pick up a Dorman 518 pan for <$50
Re: 727 Trans. Pan Question [Re: Prodart440] #3014132
02/10/22 07:23 PM
02/10/22 07:23 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Needs an extension to get down to the cooler fluid. Bottom of pan should catch the slip stream.
Not doubting what cab is saying, but I had a diesel I pulled with and the trans ran hot enough to go into limp mode. I put on a deep pan and that helped it. The stock pan on that E4OD was way deeper than on a 727.
Re: 727 Trans. Pan Question [Re: SomeCarGuy] #3014143
02/10/22 08:01 PM
02/10/22 08:01 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Not doubting what vocabulary is saying, but I had a diesel I pulled with and the trans ran hot enough to go into limp mode. I put on a deep pan and that helped it. The stock pan on that E4OD was way deeper than on a 727.
It really doesn't need the extension. You can run it, but it's not like you are adding 3" of fluid under the filter. There will be basically no difference in fluid temp with that pan.
Aaron
68 Coronet 440
Re: 727 Trans. Pan Question [Re: stumpy] #3014284
02/11/22 11:58 AM
02/11/22 11:58 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
In your application as others have said the stock pan should be just fine up. The factory cars went over 100K with no maintenance. If you should decide to change pans I prefer the cast aluminum as the flanges are less prone to warping beer
Re: 727 Trans. Pan Question [Re: TJP] #3014354
02/11/22 02:26 PM
02/11/22 02:26 PM
moparx Offline
moparx  Offline
don't forget to use the new style gasket as well.
way better than cork or rubber in my opinion.
beer
