A Body 1-7/8 TTI Headers on shelf #3013871
02/09/22 09:08 PM
02/09/22 09:08 PM
Gravataí, RS, Brazil
360tripleblack77 Offline OP
Hello Guys,
I'm looking for A-body 1-7/8 TTI Headers for my car but delivery time from TTI for these models will be in June.
Could any TTI distributor has this on shelf right now?
Thanks,
Diego
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: A Body 1-7/8 TTI Headers on shelf [Re: 360tripleblack77] #3013885
02/09/22 09:56 PM
02/09/22 09:56 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Vendor list I found off their website that has some contact info.
https://www.ttiexhaust.com/Distributors.htm
Re: A Body 1-7/8 TTI Headers on shelf [Re: Neil] #3013943
02/10/22 08:13 AM
02/10/22 08:13 AM
Washington
madscientist Offline
Washington
I would contact Tubular Automotive and buy their headers.
Re: A Body 1-7/8 TTI Headers on shelf [Re: 360tripleblack77] #3013966
02/10/22 09:45 AM
02/10/22 09:45 AM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
check out hedman 75140. I like the routing of the pipes, zero trouble with installation on my car (1968 Valiant). Downside is you have to cut a hole in the inner fender for number 7 and number 8. I´d choose these again over the tti´s. A 1 3/4" version is also available.
Michael
Re: A Body 1-7/8 TTI Headers on shelf [Re: madscientist] #3014363
02/11/22 02:45 PM
02/11/22 02:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Agreed. Wont have to cut anywhere, and will make likely a bit more power than the TTI’s.
Headman’s if you don't mind hacking inner fenders
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
