440 Dakota build #3012919
02/06/22 11:27 PM
02/06/22 11:27 PM
ky.
K
kenworth_goose Offline OP
K
ky.
Haven't posted on here in a while but here goes. I'm putting together a 440 Dakota. I bought a really clean 90 Dakota short bed and had this 440 laying around. Put a small cam in it and a set of 67 closed chambered heads to bump the compression.
Re: 440 Dakota build [Re: kenworth_goose] #3012933
02/07/22 12:50 AM
02/07/22 12:50 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I will be watching this. I have been casually looking for a 2wd Dakota to put a 440 or 3g hemi in. Anybody have suggestions on what years are the best for either of these swaps. I suppose the first ones are lighter and later years have a roomier engine compartment. What years would have 4 1/2 X 5 bolt pattern wheels?
Re: 440 Dakota build [Re: GomangoCuda] #3012957
02/07/22 08:42 AM
02/07/22 08:42 AM
MI
1990A Offline
1990A  Offline
MI
Not positive on the years with 5 bolt pattern but when i did up my 95 i was able to just replace the front 6 bolt hubs with the earlier 5 bolt direct swap and used a j-body rear axle. Nice to see the OP progress with the motor mounts i went with engine plates front and rear and used A-body hooker super comp fenderwell headers they worked out pretty good for exhaust
Re: 440 Dakota build [Re: GomangoCuda] #3012980
02/07/22 11:20 AM
02/07/22 11:20 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Nice. up Been thinking about building a small block early Dak myself. Pretty clean ones pop up on occasion for a good price around here. I'll be following your build as well.
I think '89 or '90 is the year they lengthened the front end. The earlier years take more work to put in a sb or bb. Don't remember when they changed to 6 lug wheels ('94?). There are several way more Dakota-knowledgeable folks here and hopefully they will give a definite answer.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 440 Dakota build [Re: GomangoCuda] #3013071
02/07/22 03:24 PM
02/07/22 03:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My 90 v6 had 5 lugs and 91 had 6 lug 318. The 6 lug is easy to convert to 5 lug till the new body came out in 97.
I have a super clean 2wd ex cab 92 318 I would consider selling, I don't want to give it away and they are not worth much here so I was just planning to keep it but it is really nice and could drive anywhere.
Really to do a gen 3 swap I think 08 and up would be easiest because the 4.7 computer, harness and trans can be made to work, don't know how you would make it all work on the older ones without standalones trying to get along with the stock one to keep gauges and stuff all working. I think there is plenty of room in any of the engine compartments for a gen III. The one he has in this picture is the smallest engine compartment as 91 they at least lengthened it a little to accommodate the 318.
Re: 440 Dakota build [Re: HotRodDave] #3013117
02/07/22 05:29 PM
02/07/22 05:29 PM
MI
1990A Offline
1990A  Offline
MI
That 318 dal is it a 5sp might be interested
Re: 440 Dakota build [Re: 1990A] #3013119
02/07/22 05:33 PM
02/07/22 05:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Automatic
Re: 440 Dakota build [Re: HotRodDave] #3013150
02/07/22 07:33 PM
02/07/22 07:33 PM
Falcon, CO
Mad-Max Offline
Mad-Max  Offline
Falcon, CO
cool build - that's gonna be hellafun thumbs
I have an '02 QC Dakota 4x4 that I put a 440 in, along with a ridiculous load of other off-road stuff - been handling a bunch of teething problems and just now getting it rolling...
- Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
Re: 440 Dakota build [Re: GomangoCuda] #3013756
02/09/22 03:18 PM
02/09/22 03:18 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I don't know the year cutoff, but I swapped 81/4 axles, drums and front rotors on to my 92 to make it 5 lug. It was a bolt on deal no fiddling around.
Re: 440 Dakota build [Re: mgoblue9798] #3013785
02/09/22 04:53 PM
02/09/22 04:53 PM
scratchnfotraction Offline
My son's 2000 Dak on the rear when we measured it shared the 43" perch centers same as a d150 & the A-body.
since I had my 88 d100 tubbed with the A-body 8 3/4 tucking 12" wide 4.5 backspace 29x15x15 M/Ts in the fenders with tubs flush with the frame. works on the DAK and the stock swaybar even works out bolting up.(DAK rear SB fits D100/150 truck chassis as a bolt on mod with the A-body 8 3/4.
when we were looking it was the B-body 8 3/4 that was the most popular swap for 10" rims less tub work.
after all Robert, you are the man when it come to narrowing a 8 1/4 rear axle in the driveway by hand when everyone said you can not do it that way. yes sir, I remember that well.
I would think a DAK with a 440 would need a set of fatty's and a good A-body 8 3/4 & Moser axle package.
Re: 440 Dakota build [Re: scratchnfotraction] #3013864
02/09/22 09:00 PM
02/09/22 09:00 PM
ky.
K
K
ky.
I'm using an 8 1/4 out of a 92 and I'll swap axles out of 87-90 for the 5 lugs. Fronts are already 5 lug. I need to find a car 727 and swap everything over from this rv trans. Should be a blast. I'm recovering from major surgery so this will be a slow build for another 2 or 3 months then off to the races we go. Tubbing the back of this truck could be in the future. That would be nice.
Re: 440 Dakota build [Re: kenworth_goose] #3013867
02/09/22 09:03 PM
02/09/22 09:03 PM
ky.
K
K
ky.
headers pics
Re: 440 Dakota build [Re: kenworth_goose] #3014280
02/11/22 11:44 AM
02/11/22 11:44 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Very cool build you have going. I have a 91 sport that I built into a race truck. Mine has a 11.1 compression 2000 360 magnum and 904 engine. Best pass so far has been 11.24 at 117 in the 1/4. I used 5 lug rotors from a 87 dakota on my 91. On the rear axle I used a Ford 8.8 from a 97 Ford exployer. It is a little narrower than the factory 8.25
Screenshot_20220101-124105_Photos.jpgScreenshot_20210825-124602_Photos.jpgScreenshot_20210416-115532_Facebook.jpg
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 440 Dakota build [Re: mopar65] #3014515
02/11/22 09:03 PM
02/11/22 09:03 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Did you have to cut an axle to use that rear, or use a special backspacing on the wheels?
Re: 440 Dakota build [Re: mgoblue9798] #3014588
02/12/22 02:10 AM
02/12/22 02:10 AM
mopar65 Offline
mopar65  Offline
I did not have to cut a axle and with 15x10 wheels. used 5.5 BS
Re: 440 Dakota build [Re: kenworth_goose] #3014603
02/12/22 07:00 AM
02/12/22 07:00 AM
Greenville, PA
redraptor Online tonguue
redraptor  Online Tonguue
Greenville, PA
Very nice find! I'll be watching this also! up
Re: 440 Dakota build [Re: kenworth_goose] #3115438
01/22/23 02:48 PM
01/22/23 02:48 PM
Pennsylvania
19_Dart_68 Offline
19_Dart_68  Offline
Pennsylvania
Which headers are those? B-body? What size primaries?
What engine mounts did you use to fab ?
Do you have a factory truck oil pan or an aftermarket one?
Thanks in advance. I am in the middle of my 1988 440 build...It had motor plates, but I really want to use standard mounts.
68 Dart - 440 Swap in Progress...please stand by
Re: 440 Dakota build [Re: mgoblue9798] #3118122
02/01/23 03:01 PM
02/01/23 03:01 PM
mopar65 Offline
mopar65  Offline
Also I think I could use a 15x10 wheel with 4.5/5.0 BS. But don't have any to try out right now. I would like to try like was said and widen the wheel wells and run a 15x12 wheel. I think these early dakotas look awesome with a big fat tire in the back.
Re: 440 Dakota build [Re: 19_Dart_68] #3118123
02/01/23 03:03 PM
02/01/23 03:03 PM
mopar65 Offline
mopar65  Offline
I can't answer for the op. But I have heard that with the big block a set of hooker 2 inch Abody fender well headers will work. But don't remember if you have to do any mods to get them to fit.
Re: 440 Dakota build [Re: mopar65] #3118870
02/04/23 02:38 PM
02/04/23 02:38 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Just curious what's done to the engine and transmission?
