Re: caliper piston size?
[Re: 67_Satellite]
#3012831
02/06/22 06:51 PM
02/06/22 06:51 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Anyone know off hand the piston size in a pin type early 70's brake caliper? Trying to figure the area gain going to a 4 piston set-up. Thanks in advance. Look up 1970 Challenger disc brake calipers on www.rockauto.comI looked that up for sliders a few days ago and saw one brand listed piston diameters
[Re: 67_Satellite]
#3012862
02/06/22 08:28 PM
02/06/22 08:28 PM
Posts: 3,916 usa
lewtot184
usa
After a long web search, I found one rebuilt caliper listing which actually gave dimensions. 70 m.m. piston claimed. That's 2.750 diameter which is 5.965 sq./in. Looking at the Dr.Diff 4piston X 1.75" caliper kit. 4 pistons X 1.75" dia. equals 9.621 sq./in. That's 61% more piston area. The same master cylinder output pressure acting on more sq./in. is more clamping force albeit with more required volume. Just exploring options right now. Brakes are -"OK"- now, but not great. if pressure and volume remain the same there won't be more clamping force with more area. i've been thru this. but, worse come to worse you can always swap parts back. i did a 2.75 caliper piston once with a 1" bore master cylinder; hard pedal and poor stopping. went to a 2.5" piston and a noticeable difference. tried a 15/16" master to get more pressure and it didn't work as good due to not enough volume with hard stops. settled on 1.031" master with the 2.5" piston; isn't great by any means but a lot better than the 2.75" with 1" master.
[Re: lewtot184]
#3012889
02/06/22 09:41 PM
02/06/22 09:41 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
To Dr. Diffs point about the floating caliper, here's my take on it after thinking it over while eating. With the floating caliper, the fluid pressure is actually acting on 2 surfaces which apply the pads. Think of the column of fluid in the caliper as being the "center". The force pushes outward, via the piston, on the inner pad, pushing it against the rotor while at the same time it pushes on the bottom of the caliper bore, pulling the caliper body,and the outboard pad, inward toward the rotor. It's like doubling the area "doing the work". I will probably change to a smaller master cylinder first for a number of reasons. Cheaper, less work to change, weight loss, smaller bore(more p.s.i. per pound of pedal force). The car has manual brakes to which I added the factory disc front, and "C" body 11" X 3" rear drums. Got the front set-up at a swap meet and had the 11" drums from my old Newport, so not a lot of $$$ in what I have now. It's not horrible, but I think it could be a lot better.
[Re: dragon slayer]
#3012974
02/07/22 10:35 AM
02/07/22 10:35 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I'm sorry, I just don't buy the approach of using the force of only one side of a multi piston fixed caliper to calculate force. Let's say you had two porta-power rams between two fixed supports with the pistons opposing each other with a block between them. If you pump one porta-power to a given ram pressure and then pump the other porta-power to the same ram pressure, you guys are saying the second one didn't contribute any additional force? Brain fart. I get it. In my example, the second ram is mechanically opposing the force of the first ram. If you pressurize the second ram to the same pressure as the first, you are simply substituting the mechanical opposition with hydraulic opposition, there is no additional force supplied. Got it.
[Re: 6PakBee]
#3013022
02/07/22 01:24 PM
02/07/22 01:24 PM
Posts: 19,480 north of coder
moparx
keep the manual pedal and it's ratio when swapping to power brakes. i have done that a few times, and i can tell you, it will throw you through the windshield. manual brakes have around a 6:1 ratio, while power brakes can be 3.5 to 5:1, depending on application.[pedal ratio]
[Re: 6PakBee]
#3013101
02/07/22 04:18 PM
02/07/22 04:18 PM
autoxcuda
So Cal
I'm sorry, I just don't buy the approach of using the force of only one side of a multi piston fixed caliper to calculate force. Let's say you had two porta-power rams between two fixed supports with the pistons opposing each other with a block between them. If you pump one porta-power to a given ram pressure and then pump the other porta-power to the same ram pressure, you guys are saying the second one didn't contribute any additional force? Brain fart. I get it. In my example, the second ram is mechanically opposing the force of the first ram. If you pressurize the second ram to the same pressure as the first, you are simply substituting the mechanical opposition with hydraulic opposition, there is no additional force supplied. Got it. Here’s a brake calculator and shows you have to calculate forces https://brakepower.com/help_abc_27_PAC_t.htm
