Transmission build date? #301215
04/27/09 05:45 PM
04/27/09 05:45 PM
Missouri
NFURY8 Offline OP
super street
NFURY8  Offline OP
super street
Missouri
I have a 518/46RH I was told was a 92 or 93 I am trying to nail it down exactly.
The pan rail reads
53008102 0548 8196
I believe the 0548 is the build date code.
When was it built?
Thanks!
C-Body DryDock Bigger is Better!
Re: Transmission build date? [Re: NFURY8] #301216
04/28/09 08:24 AM
04/28/09 08:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I think the 8196 is the build date ?
Re: Transmission build date? [Re: JohnRR] #301217
04/28/09 04:09 PM
04/28/09 04:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
0548 is the build date but since lightningjar is gone there's no way to look it up.
The previous 10,000 day calendar ended on 12/13/1988 so 548 days after that would put it around June 1990.
Re: Transmission build date? [Re: John_Kunkel] #301218
04/29/09 12:42 AM
04/29/09 12:42 AM
Missouri
NFURY8 Offline OP
super street
NFURY8  Offline OP
super street
Missouri
Thanks John! I was starting to question the date I was told. I found a 91 truck today with its original transmission and a higher number. The number was also stamped in a way that looked like a dot matrix, mine is solid stamped numbers. Also mine didn't have the crank sensor cut out, and the 91 did.
