speaking of one wire alternators ??
#3012002
02/03/22 07:59 PM
02/03/22 07:59 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I have another post about going to 16 Volt battery and it looks like a great idea. I see these 1 wire advertised alternators but when I look closer at them there is another plug area for another two wires What is that for ?? Most likely a dumb question but I dont want to buy the wrong alternator and have to figure out another plug . Thanks , What type . Brand are most guys using ??
6.50 @105.26
Re: speaking of one wire alternators ??
[Re: Kindafast]
#3012073
02/04/22 02:11 AM
02/04/22 02:11 AM
Posts: 1,826 South Bend
John Brown
South Bend
Absent any pictures, I'd guess it's a GM alternator and what you are seeing is the regulator. There are prongs on it that are not needed or used on a one wire alternator. Some sellers / manufacturers put a rubber plug in the hole that covers the prongs so they can't be seen.
[Re: Kindafast]
#3012113
02/04/22 11:02 AM
02/04/22 11:02 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
my GM delco-remy 1 wire from napa had a rubber plug over 2 prong hole
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3012144
02/04/22 01:26 PM
02/04/22 01:26 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Old Delcotron. I used one for years. A little big, a little heavy, but it works. Kept the batteries up. Doesn't cost hundreds of dollars, And what I like about it, the thing is easy to work on in the field. I carried parts for it and had to fix it at the track one or twice.
Self exciting regulator makes it a one wire. Most companies plug the hole so the two wire plug can't be used.
[Re: CMcAllister]
#3012178
02/04/22 03:00 PM
02/04/22 03:00 PM
Kindafast
Seaford, Va
Thanks Guys , I figured as much but was a little confused when I saw that plug spot.
6.50 @105.26
[Re: Kindafast]
#3012390
02/05/22 09:50 AM
02/05/22 09:50 AM
Posts: 138 Connellsville
71Demon528
Connellsville
I have another post about going to 16 Volt battery and it looks like a great idea. I see these 1 wire advertised alternators but when I look closer at them there is another plug area for another two wires What is that for ?? Most likely a dumb question but I dont want to buy the wrong alternator and have to figure out another plug . Thanks , What type . Brand are most guys using ?? Ya don't worry about that plug. I know that can be confusing as I was confused as well but it is not used.
[Re: moparx]
#3012455
02/05/22 01:48 PM
02/05/22 01:48 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
which begs the question, why are the two wires there, but plugged ? can this alternator be used with an external regulator using these wires ? No. Do not plug anything in there. Self exciting internal regulator. Typically, start the engine, the alternator will not work until you bring the RPM up to ~2000. Then it turns on and charges. NHRA would do tech and check the master switch by having you start the engine and then turning off the switch to verify everything stops. Those of us who had the alternators wired into the system had to be careful not to rev the engine and turn the alternator on. Then they got wise to that and made you bring the engine up to 3000 before turning off the master. So we had to fix the wiring.
[Re: moparx]
#3013057
02/07/22 02:51 PM
02/07/22 02:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Standard regulator... One wire regulator kit kit with the cover.... I don't know the answer. I expect the difference is a simple change in the circuit board. Maybe it's cheaper to use what they produce and modify it than make a large change. I think I've seen them without the spades. Most have them.
[Re: CMcAllister]
#3013081
02/07/22 03:38 PM
02/07/22 03:38 PM
Posts: 19,408 north of coder
moparx
interesting sir. Thank You ! i have never had one apart. i have just went to the Nippondenso 95 and 120 amp alternators. Thanks again for the explanation. the spiders in my old noggin fight to keep out other brand info, while making the cobwebs tough enough i can't remember Ma's info i have stuffed into there my entire life.
