Re: Alternator wiring w/MSD?
[Re: wkroncke17]
#3011932
02/03/22 04:28 PM
02/03/22 04:28 PM
Posts: 2,079 CA
crackedback
CA
The fat red wire you can run to any location that is hot, even the alt output stud if you want. It is nothing but a feed for the box. Although it may be better to pull a larger wire forward (noise buffering from battery) from the battery/downstream side of switch to a bus point.
The "important" wire is the small red trigger wire. That wire needs to be on your downstream side of the cut off switch. Cut off thrown, box goes dead, no signal. Putting the fat red on the same side also cuts of operating current.
Just depends on the approach you wish to apply.
[Re: CMcAllister]
#3011950
02/03/22 05:29 PM
02/03/22 05:29 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
One wire alternator will make life much easier. I'm thinking about that..... Already spent $40 to have the alternator taken apart an press the March Pulley on, I'm trying to be cost effective (Not really cheap) but want it to be working correctly. Is the Painless 50105 Alternator Shutdown Relay necessary to cut all power to it? Thanks all for the assistance...... Wally.
[Re: wkroncke17]
#3011984
02/03/22 07:11 PM
02/03/22 07:11 PM
Posts: 2,079 CA
crackedback
CA
CD relays are available that do the job for around $40 or less. If you want to kill that line when the cutoff is thrown.
I use Cole Hersee CD relays
[Re: Cab_Burge]
#3012003
02/03/22 07:59 PM
02/03/22 07:59 PM
wkroncke17
Wisconsin
You need the kill switch to be able to shut the current off to the car so that means the big charge wire from the alternator needs to be routed to the battery side of the kill switch and then routed back from the switched side of that switch back to the starter relay feeding (charging) the battery off of the starter. I would replace the stock battery wire with a #8 or maybe even a #6 gauge wire depending on the amperage the alternator makes, 35 amp for 35 amps,or # 6-gauge for 60+ amps. The increase length of the charging wire comes into play so a lot bigger is better than a tiny bit to small Have fun Cab, definitely appreciate your 2¢! So can this be done without a relay? As I admitted before, wiring is not my specialty, so I just can’t picture it. I’ve been looking online for a diagram, got nothing. I know once I understand it, it’ll smack me in the face….. Thanks again all!
[Re: Cab_Burge]
#3012087
02/04/22 08:53 AM
02/04/22 08:53 AM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
Here is the best solution that I found for doing this: https://www.summitracing.com/parts/mor-74107The instruction sheet is on the site to show how to wire it in. There may be cheaper versions of solenoids, but I went this route knowing that Moroso made this for doing exactly what I wanted to do.
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: TruPerformance]
#3012098
02/04/22 09:53 AM
02/04/22 09:53 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Here is the best solution that I found for doing this: https://www.summitracing.com/parts/mor-74107The instruction sheet is on the site to show how to wire it in. There may be cheaper versions of solenoids, but I went this route knowing that Moroso made this for doing exactly what I wanted to do. I have the Painless version in my Dart.
[Re: justinp61]
#3012180
02/04/22 03:06 PM
02/04/22 03:06 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
Here is the best solution that I found for doing this: https://www.summitracing.com/parts/mor-74107The instruction sheet is on the site to show how to wire it in. There may be cheaper versions of solenoids, but I went this route knowing that Moroso made this for doing exactly what I wanted to do. I have the Painless version in my Dart. Why buy two parts when one will do the job? Or are you only using one relay with a switch?
[Re: Cab_Burge]
#3012972
02/07/22 10:05 AM
02/07/22 10:05 AM
TruPerformance
S.E. Michigan
Sorry for the delayed response Cab... But just saw the question. It has been a while since i wired mine, but what I remember is most switches aren't rated to handle the voltage of the alternator going through them (?) So, the external 250 continuous duty solenoid is needed to support the alternator, and the solenoid gets wired to the switch to shut down the alternator to the battery, the switch also kills the battery feed to the rest of the car.
#3012990
02/07/22 11:39 AM
02/07/22 11:39 AM
Posts: 1,213 Minn
SportF
Minn
The unrealized problem in wiring for a trunk battery is with the car running, you have two positive sources running the car. One from the battery, and one from the alternator. If you wire it such that it turns off the battery, the alternator continues to run and power the system*. So, you either have to cut the field power to the alternator to turn it off (which requires either a 4 pole cutoff switch or a relay/solenoid) or wire the alternator output to the + battery making the car run on a single positive source.
I might add also that if that alternator output has any other connection to anyplace else other than the + battery you run into the dual + supply again.
Many people wire it wrong as in the first instance, but turning off the switch "works" at idle as the power draw is greater than can be supplied by the slow speed alternator. But note the asterisk below. More than one person has had tech inspect the cutoff at high idle and the car shuts off due to fried "stuff". ending the racing day right there in tech. Seen it, not on my stuff.
*Running the car with the battery cut out can allow the alternator to put out way too much power. I've measured 20 VDC at idle, but not for long, the MSD will die.
[Re: SportF]
#3013195
02/07/22 09:56 PM
02/07/22 09:56 PM
wkroncke17
Wisconsin
*Running the car with the battery cut out can allow the alternator to put out way too much power. I've measured 20 VDC at idle, but not for long, the MSD will die. This is exactly what I’m dealing with at the moment……. With the relay I have no problem wiring up as per the attached diagram from painless. The main question is now - what to do with the black wire that was on the post from the original wiring harness? I’m thinking undo it from the bulkhead connector under the dash and run it to a 12v source? Thanks all for the input!
[Re: SportF]
#3013309
02/08/22 11:33 AM
02/08/22 11:33 AM
Posts: 289 St.Pete,Florida
lancer493
St.Pete,Florida
It seems that this alternator to disconnect switch situation is getting way overthought, injecting too many new variables into the mix. Actual time required for protection is being overlooked. All these switch related solutions rely on driver or track crew recognition and appropriate response to operate. Not a good situation in emergency. All that is needed in the B+(output) cable between the alternator and the battery side of the master diconnect switch is an AMG or AMI 100 or 125 amp slow-blow fuse. If the alternator or its charge wire becomes shorted to ground this fuse will do it's job in seconds, much quicker and more reliable than any human interaction, which I think is actually the primary reason for this circuit in the first place. It saves using the master disconnect switch to turn off the energizing coils for soleniod based systems, when parked. Stored vehicles should always have the negative battery terminal disconnected.With a bolted terminal style fuse arrangement there are no moving parts to wear out or fail on race day. The alterntor and it's charge circuit are then protected from a direct short 24/7 even if the negative cable isn't disconnected when parked. So many high end cars are manufactured this way. Hope this helps. Also, this fuse should be as close to the disconnect B+ terminal as possible to protect the wire from shorting too. Bill
[Re: Cab_Burge]
#3013404
02/08/22 03:41 PM
02/08/22 03:41 PM
Posts: 95 Cumming Georgia
cspracer
Cumming Georgia
Cab, here is an off the wall question. If you are not running an alternator, can you get rid of the thick wire going from the starter relay down to the starter solenoid, or does this also serve another purpose? As I was rewiring mine back up I wondered why that wire was there, since it seemed redundant because the starter has a heavy wire directly to the battery. Just curious.
1968 - 383 Roadrunner 4 speed street car, Dad bought new 1970 - 440 Roadrunner drag footbrake car 6.99 1/8th 2016 - Hemi RAM 1500 - Hauls all the toys North Georgia / Central NC
[Re: cspracer]
#3013443
02/08/22 04:41 PM
02/08/22 04:41 PM
Cab_Burge
Mopar used that big black, some are red, wire from the battery post on the solenoid to feed the rest of the car electricidal circuits off of the starter relay: scope:
[Re: Cab_Burge]
#3013479
02/08/22 06:22 PM
02/08/22 06:22 PM
cspracer
Cumming Georgia
Cab, your right. That makes sense. Now that I have everything run through my own switches, which go directly to the battery, I can likely delete that wire as well. Just trying to keep things as simple as possible. I have seen some of those switches with a ton of things run to them.
