thermo-quad
#301062
04/27/09 02:07 PM
04/27/09 02:07 PM
Posts: 63 minnesota, USA
greenfire
minnesota, USA
any one know what the cmf this themo-quad is? i pulled it off my 318, only #on it are 6-2141 and the #16 in larger size#
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: thermo-quad
[Re: greenfire]
#301063
04/27/09 02:22 PM
04/27/09 02:22 PM
i think its 850 but not sure. what do you plan on doing with it?
Re: thermo-quad
#301064
04/27/09 02:25 PM
04/27/09 02:25 PM
sorry i mistyped. should be between 750 and 800. i think 750 was the smallest thermoquad.
Re: thermo-quad
[Re: stumpy]
#301066
04/27/09 02:37 PM
04/27/09 02:37 PM
are you looking to rebuild it or replace it. if replacing it a 600cfm eddy or holley would be a better choice. if you go with a 750 or bigger aftermarket they will bog out the engine a bit.
Re: thermo-quad
[Re: stumpy]
#301067
04/27/09 02:39 PM
04/27/09 02:39 PM
Posts: 7,506 Az
Crizila
Az
If the primary bores are 1 3/8", it is a 750 -800cfm. 1 1/2 primarys = 800 - 850 cfm.
Fastest 300
Re: thermo-quad
[Re: DEMONSIZZLER]
#301070
04/28/09 12:17 PM
04/28/09 12:17 PM
greenfire
minnesota, USA
thanks guys, looks like it is a 800cmf tq a bit to much carb for a stock 318 imo. and the intake prolly had more leaks then a block of swiss cheese, what a mess lol. gonna put on edelbrock intake with a edelbrock 1405 600 cmf carb to day.
Re: thermo-quad
[Re: Rug_Trucker]
#301071
04/28/09 07:29 PM
04/28/09 07:29 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
A TQ will adjust it's CFM via engine demand and a properly adjusted air door.
Read that again. It really seems like you have no experience with carbs. You have the best carb in your hand for a mild engine.
Let Demonsizzler rebuild it. It would be cheaper and better than any after market NEW carb you could buy.
Did you get the model number off it??
Re: thermo-quad
[Re: Rug_Trucker]
#301072
04/28/09 07:37 PM
04/28/09 07:37 PM
Posts: 2,251 ILLINOIS
volaredon
ILLINOIS
Ive had a few 318s with aftermarket carbs and none ran as well on there as a TQ. I'm gettin ready to send him (2) baseplates for a rebush job, now that he sent me his address today for shipping.
Re: thermo-quad
[Re: HotRodDave]
#301075
04/28/09 08:25 PM
04/28/09 08:25 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Keep in mind the rules change when dealing with a squarebore vs. a spreadbore carb.
A square bore had the same size primaries and secondaries which flow almost equal. So if you go too big with a squarebore the primary venturi's might be so big that the low speed "around the town" vacuum signal suffers.
With a spreadbore, especially one with a huge difference in size between the primary & secondaries like a TQ you can worry less about overcarburating since the primaries are so tiny and very responsive.
Think about this. Holley recomends that you undersize a carb vs too big so the car will have decent idle and midrange characteristics but the magazine builds always find more HP with an oversize Carb. A spread bore is the best of both worlds for a street/strip setup.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: thermo-quad
[Re: greenfire]
#301077
04/29/09 10:24 AM
04/29/09 10:24 AM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
Tons of info here: Thermoquad guide Manuals, kits, and other stuff here: Carb Dr. The adjustable air door works great on a Thermoquad. I used the same carb on a 318, then on a 440, and it got me 14.20@98MPH with a junk yard motor in a '69 Coronet. Same car with the 318 and that carb was much slower, but never any bog or mixture problems.
