440 Truck Camshaft #3010461
01/30/22 07:24 AM
01/30/22 07:24 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I'm building a 67 440 to put in my pickup and curious as to what cam I should go with. The engine has been bored .020, I'm using a flat top piston with .991 comp height and 452 heads. The block and head mating surfaces have not been cut. Best I can figure is somewhere around 9.3 compression using .020 steel head gaskets. Trans is a 727 with factory convertor, not really sure what it stalls at.
It's going in a 77 D100 swb, 3.23 gears and 28 inch tall tires. The truck weighs 4100lbs with me in it. What say you.
Re: 440 Truck Camshaft [Re: elmor353] #3010477
01/30/22 09:21 AM
01/30/22 09:21 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Melling P/N mtd-2
Re: 440 Truck Camshaft [Re: B1MAXX] #3010479
01/30/22 09:34 AM
01/30/22 09:34 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I would say you are looking for low/mid range power band correct? If so choose the cam accordingly. What other engine mods?
Re: 440 Truck Camshaft [Re: Moparite] #3010480
01/30/22 09:39 AM
01/30/22 09:39 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Depends on weather you want your truck to run like truck or a car. I have a 77 360 with X heads and a 480 lift cam in my 78 D100 swb. Runs more like a muscle car than an old truck but that is what I wanted. I don't tow or haul heavy loads. I do a couple burnouts every so often though.
So what is your liking?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 440 Truck Camshaft [Re: B1MAXX] #3010515
01/30/22 12:54 PM
01/30/22 12:54 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You could do worse than the small summit cam.
Re: 440 Truck Camshaft [Re: fast68plymouth] #3010534
01/30/22 01:41 PM
01/30/22 01:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
something like this would probably work good
https://www.summitracing.com/parts/sum-k6400/make/chrysler
Re: 440 Truck Camshaft [Re: Dodgem] #3010538
01/30/22 01:50 PM
01/30/22 01:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the summit 6400 is close to duplicating a stock magnum. the summit cam has 112lsa vs 115lsa for the magnum. i think the magnum has a little more seat timing in part due to the long closing ramps. either would be good choices but the 6400 may be the only one of the two available. i put a 6400 in a 383 once with no regrets.
Re: 440 Truck Camshaft [Re: elmor353] #3010581
01/30/22 04:05 PM
01/30/22 04:05 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Is this a play toy or a working truck? If compression truly is 9.3 to one pick carefully so you don't build a detonation prone monster. Since you mentioned block has not been decked I am going to bet you don't have nearly the compression you think though. Those pistons will be way down in the bore.
Re: 440 Truck Camshaft [Re: mgoblue9798] #3010583
01/30/22 04:18 PM
01/30/22 04:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
Just running the numbers quick for uncut parts(pistons down the hole .086”, 88cc heads)....... I come up with 8.8:1.
Re: 440 Truck Camshaft [Re: fast68plymouth] #3010710
01/31/22 12:36 AM
01/31/22 12:36 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Manifolds or headers?
I’ll say a stock hp muscle era grind is the outer limits. Smaller with manifolds, closer to it with headers.
I want my fair share
Re: 440 Truck Camshaft [Re: SomeCarGuy] #3010731
01/31/22 04:24 AM
01/31/22 04:24 AM
E
elmor353 Offline OP
elmor353  Offline OP
E
The truck has headers and dual exhaust. Pistons are .070 in the bore. I use the truck for cruising mostly, with an occasional dump or scrap run. I am not opposed to a few burnouts per year.
Re: 440 Truck Camshaft [Re: elmor353] #3010741
01/31/22 08:05 AM
01/31/22 08:05 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
These engines were always ‘under cammed’...
My mates 66 440 was totally stock with 452 heads and a 484 sixpack DC camshaft, went like a scalded cat...
I would recommend one step down and go with the 474...
Back in the day we would buy the biggest cams we could find!
Hughes engines are just going with the BIG cam theory now, 40 years after we did lol...
Big Is Best, don’t starve the beast...
I took a cam out of a 440 motorhome engine and it was 390 lift.
The guy who ran the MH said, “it wouldn’t get out of its own way” lol...
Compcams 270 I think they call it now?
That’s a hipo 440 cam with 270 duration.
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 440 Truck Camshaft [Re: Gtxxjon] #3010757
01/31/22 10:27 AM
01/31/22 10:27 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the mopar "284-.484" cam would be a definite no-no. a D.C. sixpak cam is the same as a stock 4bbl magnum cam as far as valve timing and lift and i'd say ok to that. the biggest problem i have with any of the small comp cams hydraulics is the 110lsa and 4 degrees advance no matter what flavor you buy. the 268/276 comp cams may be ok but i'd want 112lsa and no advance ground into it for starters. the summit 6401 surprisingly does have fairly good low and mid-range torque considering it's definitely more cam than a stock cam. i'm at a point in life where i lean more and more towards the gentler cams for something to drive. i've thought about having a comp cams cam ground with the 276/.464 lobe on 112lsa -113lsa to replace the mopar 272/.455 (also thought about a 276/284 @ 112lsa for a street performance cam). howards lists the intake lobe of the summit 6401 so a single pattern cam could be ground (this would be something like 280@.006", 224@,050", 133@.200" lift and .466 lift) on a 112lsa and make a nice driver.
Re: 440 Truck Camshaft [Re: elmor353] #3010789
01/31/22 11:46 AM
01/31/22 11:46 AM
scratchnfotraction Offline
if it is below 9.5 comp ratio- on my junk I go with Hughes steamroller or whiplash cams.
my 88-D100 with a bone stock 78 MH 440 with the Hughes 440 whiplash cam is awesome! very choppy but smooths out about1800-2000 rpm for the street truck. recurve dist.- fatten up the 650DP with a stock MH converter -any of my gears 3.91-3.23-2.76 turning a 29x15x15 M/T running the 2.76 gear at the moment for longer cruzing. sounds like a Funny Car cruz like a Chrysler New Yorker on the streets. idles along in 3rd gear 1200 rpm @ 25 mph in town choppin wood as they say.
I run 2 Hughes "steamroller" roller cams in 318s and 1 "whiplash" roller cam 318 and 1 440-whiplash flat tappet cam all in trucks on the street. they all work well with low comp stock everything as advertised. fatten up the carb and recurve the dist with a set of 925B springs has been all that was needed with them.
I have had the one SB roller cam in a few engines and over 200,000 miles on it now not one problem with them.
got about 27,000 miles of fun on my flat tappet whiplash cam now.
I am sure there are better faster cams out there but on lopo engines they work really well in traffic.
Re: 440 Truck Camshaft [Re: scratchnfotraction] #3010884
01/31/22 04:51 PM
01/31/22 04:51 PM
Falcon, CO
Mad-Max Offline
Mad-Max  Offline
Falcon, CO
...while I haven't had it out on the main streets yet to see how well it does, the Engine Pro MC1787 is the cam I put in my 440 - it was what came in the engine master rebuild kit ordered from the machine shop). It idles smooth, and from the few hours it's been running /driving around the property it seems to have loads of torque. My truck was built to be a multi-purpose camping/rock-crawling rig that is also 100% streetable - it rolls on 40" Toyos with 5.38 gears. I found the engine buried deep inside a '79 Winnebago Motorcoach - it is a 440-3 block with standard 452 heads, and got a standard 'RV' rebuild with ~9-1 compression.
Engine Pro MC1787, hydraulic flat tappet
- Duration @ .050 Intake 204 Exhaust 214, Advanced Duration Intake 278 Exhaust 288; Valve Lift .420 Exhaust .443
- Lobe Sep. Intake 107 Exhaust 117; Power range 1500-4000; Idle: Smooth
- Comment: Torque Cam strong low to mid range torque and pulling power.
- Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
Re: 440 Truck Camshaft [Re: Mad-Max] #3010896
01/31/22 05:35 PM
01/31/22 05:35 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Thanks for all the replies. Years ago I had another 67 440 with the same pistons, heads and factory intake. It was bored .040 and I used factory HP exhaust manifolds. I ran the Mopar 274/474 cam. I had it in a Duster with 3.91 gears and factory high stall convertor. That car was fun to drive! I suppose the Summit cam would work for what I want. I very rarely tow anything with the truck and the 6401 cam doesn't sound like it would be too lumpy anyway. Also, I have a new one sitting on the shelf, that I bought for another project and never used is a plus.
Re: 440 Truck Camshaft [Re: Mad-Max] #3010907
01/31/22 05:59 PM
01/31/22 05:59 PM
Apollo, PA.
Apollo, PA.
- Sam
Thats the melling mtd-2 up
Re: 440 Truck Camshaft [Re: elmor353] #3010911
01/31/22 06:13 PM
01/31/22 06:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
put that 6401 in it if you have it. they have a smooth idle and good torque; mimics a crane hmv278. you could do worse.
Re: 440 Truck Camshaft [Re: lewtot184] #3011036
02/01/22 08:23 AM
02/01/22 08:23 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Any cam around 450 lift and 260 duration will work.
But the LSA can have a huge affect on vacuum and idle characteristics of course!
We checked a lot of cams and you rarely get ‘more’ cam than less it seems...
If you buy a stockish 440 cam it will run good, but come the day you meet an F100 or Chev truck.
You will wish you had the 474 lol...
You want ‘bub, dee, blab’ not blah, blah, blah... drive drinking XmasTruck
Re: 440 Truck Camshaft [Re: elmor353] #3011040
02/01/22 09:05 AM
02/01/22 09:05 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The standard Magnum Cam run good on the detuned engines since 72 ( is the cam on 400Magnum engines and lates 440 Magnums ) with 8:1 CR and open chamber heads. With given specs I think one step higher of the Magnum Cam will be fine. Crower 267 HDP maybe ?
