restorick undercoating
#3008813
01/25/22 12:31 PM
01/25/22 12:31 PM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I was researching undercoating options last week and was comparing RestoRick's undercoating with 3m body shutz. I didn't complete the order form on RestoRick's website but I recieved an invoice anyway. Looks like I'll order it from him...it's less expensive then the 3m stuff anyway. What I was curious about is how you go about spraying it. The 3m body shutz comes in 1 quart containers that screw on to the applicator gun. RestoRick's stuff comes in a gallon container. Does the shutz gun screw to the gallon can or do you have to transfer it to another container to spray it? I saw this gun listed in an old Moparts thread. This is what I'll probably buy to spray it. https://www.amazon.com/gp/product/B003D3N7W4/ref=pd_lpo_sbs_dp_ss_1
Re: restorick undercoating
[Re: topside]
#3008956
01/25/22 06:58 PM
01/25/22 06:58 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Transfer Resto Ricks undercoating to the smaller gun reservoir. I then drill out the gun nozzle to a larger diameter. Then to get the build up like the factory I shoot a heavy coat and then let it dry over night or so then come back and do it again. If you keep building it up on the first pass it will flow out as it cures and you won't get the build up. Also a minimum of 4 beers are needed to get into the factory worker's state of mind.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: burdar]
#3009245
01/26/22 02:59 PM
01/26/22 02:59 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
The gun listed in the link doesn't show an extra reservoir. That's why I was confused. So it looks like I'll have to come up with some sort of reservoir to pour the undercoating in. I do have one of those cheap non-gravity paint guns that's never been used. Maybe that reservoir will work? most auto body supply stores should be able to sell you a new empty can. I have bought them from my paint jobber ABS here in Sioux falls SD absdelivers.com corey
Contact Me about AMD Prices
[Re: hotairballoonpilot]
#3009353
01/26/22 07:10 PM
01/26/22 07:10 PM
Posts: 601 Mass
charge70
Mass
Just purchase a quart of the 3m undercoat,use it as a base and now you have a container to spray resto Ricks stuff.Thats what I do
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: MOPARMIKE69]
#3009388
01/26/22 08:35 PM
01/26/22 08:35 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Transfer Resto Ricks undercoating to the smaller gun reservoir. I then drill out the gun nozzle to a larger diameter. Then to get the build up like the factory I shoot a heavy coat and then let it dry over night or so then come back and do it again. If you keep building it up on the first pass it will flow out as it cures and you won't get the build up. Also a minimum of 4 beers are needed to get into the factory worker's state of mind. Lots of truth to this. There is a reason most painters, including myself, drink or smoke weed.
[Re: mgoblue9798]
#3009578
01/27/22 01:20 PM
01/27/22 01:20 PM
Posts: 19,380 north of coder
moparx
waaay back in the mid 70's, a buddy of mine and i "started" the trend of painting EVERYTHING body color. when i would get a car in at my junkyard that was good enough to fix and flip, i would contact my buddy, and he would round up all his leftover paint from his body shop. mix it all up until we got the neat-o color we wanted, then spray away after masking the windows and lights. no chrome for us ! each car we did that way sold FAST ! i don't know if it was the colors we came up with, or the price we put on the car. we also included a pint or so [or what ever was left of the "custom" mix] for touch up. good luck matching up the color. at least we take credit for "giving" the manufactures "our" idea.
[Re: LimeliteAero]
#3009648
01/27/22 03:56 PM
01/27/22 03:56 PM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I like the idea mentioned about hogging out the nozzle. Any idea on the size to increase it to?
[Re: MOPARMIKE69]
#3012367
02/05/22 06:39 AM
02/05/22 06:39 AM
Posts: 22 North Carolina
dge330
North Carolina
Transfer Resto Ricks undercoating to the smaller gun reservoir. I then drill out the gun nozzle to a larger diameter. Then to get the build up like the factory I shoot a heavy coat and then let it dry over night or so then come back and do it again. If you keep building it up on the first pass it will flow out as it cures and you won't get the build up. Also a minimum of 4 beers are needed to get into the factory worker's state of mind. yep sounds about right . the last part is the most important one .
