Re: Oil Change Setup
[Re: Mastershake340]
#3008812
01/25/22 12:29 PM
01/25/22 12:29 PM
Posts: 20,826 A collage of whims
topside
A collage of whims
Sounds like the quickie place just tossed a cartridge in without seating it, and then cranked down on the cover ? All my stuff is can-style - newest vehicle I own is a '97. If I don't have the car on stands, I have some 2x6 wood ramps I made to drive up on; doesn't need to be too high. Sheet of cardboard, drain pan & filter wrench, fill the new filter before installing. Simple. Some cars are laid out so it's easy to get filter oil all over stuff; for those I use aluminum foil or a shallow aluminum cake pan to guide the oil into the drain pan. I grab drain plug washers with the seal in their ID from the local parts store. Get a garage, man ! Maine's too dang cold
[Re: topside]
#3008818
01/25/22 12:48 PM
01/25/22 12:48 PM
Posts: 19,488 north of coder
moparx
i use drive on ramps for my oil changes. my bus [99 caravan] and my wife's 94 chrysler concorde. the filters are easy to get to. just scoot a piece of cardboard under, plus a slightly oversize drain pan, and easy done. pre-fill the filters before installation. i use wix filters. biggest problem is my old body takes 3 hours to do a job that used to take 45 minutes.
[Re: moparx]
#3008827
01/25/22 01:10 PM
01/25/22 01:10 PM
Posts: 4,781 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Buy ramps. If your cars are low to the ground you must buy appropriate extended ramps. Make sure you have a location that will take in your old oil. Auto Zone used to take it. Buy oil filters in bulk. I buy name brands from Rock Auto for my Camrys. I also buy jugs of appropriate oil. Walmarts Super Tech brand is a great oil at a great price. The biggest thing is making sure you can conveniently (and legally) dispose of your drain oil. The jugs the oil comes in are great for your drain oil. Get a drain bin with a nice easy pour spout that fits into the oil jugs opening.
Keep old mopars alive.
[Re: Neil]
#3008877
01/25/22 03:02 PM
01/25/22 03:02 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I drain mine by letting them sit overnight and then put the drain plug, filter, and new oil back in the next morning. Longer drain time allows more of the dirty oil to get out. That's the way I do it, too. The cardboard idea is good to catch all the drips. And I like the Wix filters myself. O'Reilly's house brand filters are Wix and a couple of bucks cheaper. Around here, Rural King has the best price on oil. $13.49 for a 5 quart jug of conventional.
Master, again and still
[Re: Andrewh]
#3008889
01/25/22 03:52 PM
01/25/22 03:52 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I have a similar one to this. All my life I've been an oil plug snob eschewing the vacuum setup. I used it on my '13 300 pentastar (on the pentastar you completely avoid having to get under) and now use it for my John Deere. I still get under the old stuff but I don't see any real reason to do so except habit. They work very well, no spills is a big advantage.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: moparx]
#3008899
01/25/22 04:16 PM
01/25/22 04:16 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
i use drive on ramps for my oil changes. my bus [99 caravan] and my wife's 94 chrysler concorde. the filters are easy to get to. just scoot a piece of cardboard under, plus a slightly oversize drain pan, and easy done. pre-fill the filters before installation. i use wix filters. biggest problem is my old body takes 3 hours to do a job that used to take 45 minutes. This and as 2boltmain also said Buy Ramps. Good because it also puts most vehicles in the tilted rearward angle to help drain. Get a large plastic pan used for small concrete mixing at the local home improvement store, get the right tools ready, drive it up on the ramps and shouldn't take a young person too long. Most time is used waiting for the oil to drain and clean up. I always put the oil change milage onto the new filter along with a piece of duct tape under the hood for the next change. If the oil change quantity for the vehicle is more than 5 quarts then I just buy two 5qt bottles to take advantage of those free or reduced price oil filters that most auto parts stores run as promotions, Even getting a different filter for another vehicle in the fleet at the time. Way cheaper than buying individual qt bottles to make the fill quantity needed at the time. RAMPS.
[Re: Sniper]
#3008917
01/25/22 05:20 PM
01/25/22 05:20 PM
Posts: 4,740 Florida
BDW
I put this on all our cars, makes it so much easier Never searching for the right socket, or getting burned by hot oil when you pull the plug out, or chance of stripping threads on the way back in https://www.fumotousa.com/
[Re: BDW]
#3008965
01/25/22 07:28 PM
01/25/22 07:28 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Kinda cool, but for $25.88, I'll pass.
[Re: BDW]
#3009073
01/26/22 06:16 AM
01/26/22 06:16 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
I have the basics:
- One heavy duty drain pan with spigot (to drain into very large jugs to take to disposal) - Good set of ramps - One metal clamp style oil filter wrench - One forceps style oil filter wrench - Metal Funnel - Brake Clean Spray
I do oil changes for friends now seeing as how many places locally are either booked solid, charge crazy prices (long gone are the days of the $19.99 oil change!) or do poor quality work. But with the tools above, I haven't had anything come close to defeating me.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
#3009131
01/26/22 10:49 AM
01/26/22 10:49 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I'm pretty sure even Walmart takes used oil. Yes they do, I used to buy a drain pan to change my oil on drag week, then just give the whole thing back full of oil lol.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3009135
01/26/22 10:59 AM
01/26/22 10:59 AM
Posts: 10,736 North Dakota
6PakBee
North Dakota
Around here a number of shops have waste oil heaters, never have a problem getting rid of used oil.
