Have a Flaming River disconnect switch and plan on moving it. So, I need to make a rod and heim joint end. What size bolt is used to attach the heim joint to arm 1/4 or smaller? Also what diameter rod or tubing is used to the push/pull handle? Will be about 14" long. Thanks
