How to clean out 6.4 intake #3004058
01/11/22 09:30 AM
01/11/22 09:30 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Hello.
I acquired a 2016 6.4 intake from a Jeep SRT blown engine.
I has piston pieces in it.
Is their a way to properly clean it out? If so how?
69 Dart
Re: How to clean out 6.4 intake [Re: onig] #3004162
01/11/22 02:51 PM
01/11/22 02:51 PM
Cab_Burge Online work
Cab_Burge  Online Work
Cleaning solvent and then hot soapy water and blow it out with high air pressure wrench
Check it thoroughly before using up
Re: How to clean out 6.4 intake [Re: Cab_Burge] #3004231
01/11/22 05:32 PM
01/11/22 05:32 PM
okla.
sam64 Offline
sam64  Offline
okla.
I wouldn't trust cleaning it because unless you can split it apart there is no way to know you get everything out .
Re: How to clean out 6.4 intake [Re: Cab_Burge] #3004234
01/11/22 05:35 PM
01/11/22 05:35 PM
okla.
sam64 Offline
sam64  Offline
okla.
The 2 piece molded and sealed together intakes these use makes it pretty much impossible to know you have everything flushed out.
Re: How to clean out 6.4 intake [Re: sam64] #3004240
01/11/22 05:38 PM
01/11/22 05:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I totally agree, unless you can account for every spec of a broken piston and or valve seat that is missing there is no way to know if you got it all out.
Re: How to clean out 6.4 intake [Re: HotRodDave] #3004327
01/11/22 09:18 PM
01/11/22 09:18 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Do not use that intake. You are asking for problems.
Re: How to clean out 6.4 intake [Re: onig] #3004442
01/12/22 07:49 AM
01/12/22 07:49 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Assuming it's got the active intake with variable runner length, I'd imagine there's lots of little areas that could hold bits and pieces. Easy to say just go buy another one, but they aren't cheap, but neither are short blocks. Cut your losses gets my vote
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: How to clean out 6.4 intake [Re: onig] #3004936
01/13/22 03:05 PM
01/13/22 03:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Get a camera that attaches to your phone.
Probe the inside of the intake.
Takes nothing but time.
Matt
Re: How to clean out 6.4 intake [Re: HotRodDave] #3008077
01/23/22 07:57 AM
01/23/22 07:57 AM
Canada
onig Offline OP
onig  Offline OP
Canada
I can agree with those statements.
69 Dart
Re: How to clean out 6.4 intake [Re: MattW] #3008078
01/23/22 07:57 AM
01/23/22 07:57 AM
Canada
onig Offline OP
onig  Offline OP
Canada
Matt
Thought about this as well.
69 Dart
Re: How to clean out 6.4 intake [Re: onig] #3012751
02/06/22 02:23 PM
02/06/22 02:23 PM
Dyno1 Offline
Dyno1  Offline
Clean it out well and spray with a pressure washer. Use a camera if it makes you feel better. It will be fine. If you decide not to use it, I will buy it. Dyno
