Re: Who has broken a cast 440 crank? [Re: lewtot184] #3007759
01/22/22 12:22 AM
01/22/22 12:22 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Got me thinking, I’ll weigh the ones I have tomorrow.
Re: Who has broken a cast 440 crank? [Re: cudaman1969] #3007773
01/22/22 04:24 AM
01/22/22 04:24 AM
I saw one of my forged steel 440 cranks broken on a press, it had spun a rod bearing and it was bent . The crank repair company put it in the press and was in the process of straightening it before working onit an BANG, it broke at one of main bearing to rod throws whiney
I did have a customer who had cast crank in a 454 Chevy 1 ton crew cab ranch truck break a crank in SO CA about 60 miles from home and drove it home and around 25 miles back into town to a repair shop, the shop brought me the motor to rebuild is how eI know it was broken and driven that way shruggy
Re: Who has broken a cast 440 crank? [Re: Cab_Burge] #3007777
01/22/22 07:25 AM
01/22/22 07:25 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Seen a few broken forged cranks, but never a cast one?
My mates 70 R/T Charger was driving around with a totally sheared crank.
It made a strange rattling noise but seemed OK?
I’ve also seen a hemi Barton 572 crank in three pieces too.
That didn’t run too good though... spank
But some folks do run cast as they is lighter and are not prone to breakage.
Where the limit is, we may never know.
Too many steel cranks around for big blocks, unlike Ford guys... fan
If you read about the 360 small block guys, they love ‘em lol... drive
I saw a dropped valve 360 engine that was destroyed and the crank was fine... drinking
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Who has broken a cast 440 crank? [Re: Gtxxjon] #3007787
01/22/22 09:32 AM
01/22/22 09:32 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have a friend who was a ford racer and ford steel cranks are rare. He used cast cranks without issue but thought that limiting rpm was the key to longevity. i have noticed that some cast cranks have fillets, which is good, but mopar doesn't.
Re: Who has broken a cast 440 crank? [Re: lewtot184] #3007849
01/22/22 01:25 PM
01/22/22 01:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
On the scales just now, bathroom scale but high quality, each crank set in the same spot on scale twice.
Cast 440-67 pounds
Stock steel 440- 69 pounds
Stock Hemi been worked, out of a S/S 68 pounds
Kellogg Hemi with mallory 75 pounds
Ohio 4.15 73 pounds
Ohio 4.5 73-74 pounds
KB stock stroke blower crank 74 pounds
Have a 6 pac crank but was in garage and didn’t measure it (been internally balanced)
You numbers may come up different but they were all relative to each other
Re: Who has broken a cast 440 crank? [Re: lewtot184] #3007850
01/22/22 01:33 PM
01/22/22 01:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A friends 460 cast crank broke at speed not a pretty sight. Everything, cam, rods, cam journals, the whole center of engine were in small pieces in the oil pan. 69 Mustang running 6.20s all steel, so he was making some heat.
Re: Who has broken a cast 440 crank? [Re: cudaman1969] #3007955
01/22/22 06:51 PM
01/22/22 06:51 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
So nobody has broken a cast 440 crank?
Maybe we had it backwards all along and the cast one is better than the forged one. fan
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Who has broken a cast 440 crank? [Re: 69dart] #3007961
01/22/22 07:34 PM
01/22/22 07:34 PM
A727Tflite Offline
A727Tflite  Offline
Using a cast crank just teaches you to tip toe. Plenty of stocker guys using them.
Re: Who has broken a cast 440 crank? [Re: A727Tflite] #3007996
01/22/22 09:52 PM
01/22/22 09:52 PM
AndyF Offline
AndyF  Offline
Mazzolini used to run a cast crank in his Super Stock car just to save some weight. That was a buzz saw of an engine. Personally I wouldn't do it but the NHRA guys are a little crazy. They would sell their mom into slavery for a tenth.
Re: Who has broken a cast 440 crank? [Re: AndyF] #3008074
01/23/22 07:44 AM
01/23/22 07:44 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Andy you exaggerate a bit there, .05 and their Mothers, sisters, daughters are gone!
Re: Who has broken a cast 440 crank? [Re: quickd100] #3008214
01/23/22 03:05 PM
01/23/22 03:05 PM
moparx Online content
moparx  Online Content
what about their dogs ? do they keep them ? biggrin
beer
Re: Who has broken a cast 440 crank? [Re: 69dart] #3008739
01/25/22 09:57 AM
01/25/22 09:57 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Alright this is getting annoying...
The cast cranks are cast STEEL. All of the Mopar cranks are STEEL.
Vent over, carry on...
Re: Who has broken a cast 440 crank? [Re: 73DAD] #3008764
01/25/22 10:56 AM
01/25/22 10:56 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i will be running a cast crank in my 400 stocker this year, keep you posted, my machine shop has not seen any 400's break stock rods or cranks. i did break a scat 4.15 (offset ground 4.25) in my 540 super gas car (trans brake 5500 rpm)
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Who has broken a cast 440 crank? [Re: 73DAD] #3008794
01/25/22 11:50 AM
01/25/22 11:50 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Are they really cast steel or cast iron ?
Inquiring minds.............
Re: Who has broken a cast 440 crank? [Re: hemienvy] #3008868
01/25/22 02:45 PM
01/25/22 02:45 PM
cast STEEL..................
beer
Re: Who has broken a cast 440 crank? [Re: moparx] #3010052
01/28/22 05:20 PM
01/28/22 05:20 PM
gregsdart Offline
gregsdart  Offline
beer
if your offered something off thier barbie and it tastes a bit different,,,, 😁
Re: Who has broken a cast 440 crank? [Re: hemienvy] #3010082
01/28/22 07:44 PM
01/28/22 07:44 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
True 100% cast iron is very soft compared to cast steel used for crankshafts. Now if it is a cast Eagle 360 crank it is cast out of playdough.
Re: Who has broken a cast 440 crank? [Re: 69dart] #3010110
01/28/22 09:27 PM
01/28/22 09:27 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
The previous shortblock in my wife's 70 Barracuda had a cast crank. It held up fine to years of abuse, running 10s with Indy heads in a 70 Charger, and then mid to low 11's with 906 heads in the Barracuda. The crank is still fine, actually. It's the 1/3 of the LY rod from #7 that ended that shortblock. It exited out the side of the block and broke the starter off the bellhousing. grin
