speedometer gear
#3006971
01/19/22 09:11 PM
01/19/22 09:11 PM
Posts: 24 Richmond Ohio
alexdodge2
Richmond Ohio
After restoring my 64 dodge I replaced the 14 inch wheels to 15. Now the speedometer reads 5 mph more at 60 mph. So do I need to go to a gear with more or less teeth to correct the speedometer reading? I forgot to mention that I went from a 2.76 to a 2.94 post. I could not find a chart in the service manual to figure the new gear tooth. Now what do I need to do? thanks
Re: speedometer gear
[Re: alexdodge2]
#3007097
01/20/22 09:06 AM
01/20/22 09:06 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Pull your current speedo gear, count the teeth, multiply by 1.0833 to find the tooth count you need now, obviously you'll round off to the nearest whole number. Last time I checked (long ago, it could be a curve, I was looking in a fairly narrow range, I assumed it was linear) the worst you could be off was 1.8%, so each tooth represents ~ 3.6% difference. So probably 2 or 3 more teeth. 2ยข
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3007114
01/20/22 10:34 AM
01/20/22 10:34 AM
Andrewh
[Re: alexdodge2]
#3007198
01/20/22 02:02 PM
01/20/22 02:02 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
You already know your gear ratio so just measure your tire diameter and head here. http://www.moparts.org/Tech/tech/pages/speedo.htmlTotally disregard the above link if you still have the 62 - 65 trans. it probably needs the small speedo gear instead of the ones in these charts. Measure the tires and call Brewer.
