hemi oil pan
#3006779
01/19/22 01:21 PM
01/19/22 01:21 PM
Posts: 1,608 westerly, ri. usa
440lebaron
westerly, ri. usa
hi need measurement of hemi oil pan 6 qt stock rear of sump to rear edge and front of sump to front edge, I can notch front cross member, but cannot move center tie rod link, 1975 b body 400 stocker
called milidon, they said would not fit
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: hemi oil pan
[Re: 440lebaron]
#3006835
01/19/22 03:26 PM
01/19/22 03:26 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
https://engine-swaps.com/Pages/ProductsType/OilPanSchematics.html
Re: hemi oil pan
[Re: 440Jim]
#3006859
01/19/22 04:42 PM
01/19/22 04:42 PM
Posts: 16,928 NC
440Jim
NC
Re: hemi oil pan
[Re: 440Jim]
#3006863
01/19/22 05:11 PM
01/19/22 05:11 PM
440lebaron
westerly, ri. usa
THANKS looks like hemi pan will clear my tie rod, definitely will have to notch k-frame, wix makes a 2 qt filter (1773), maybe can use with stock 5/4 qt pan, would like to get more oil in pan, nhra stocker has to have stock style pan rule states I can notch crossmember for oil pan removal
Re: hemi oil pan
[Re: 440lebaron]
#3006928
01/19/22 07:46 PM
01/19/22 07:46 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
The pan you have looks like the 1966 to 1969 Hemi pan based on how it hangs down below the K member, the Hemi cars and some of the 440 cars had a skid plate welded on them to help prevent those oil pans from dragging and hitting over speed bumps when going fast Look at Summit for their 1970/1971 hemi and six Pack 6-quart oil pans and the stock 3/8-inch RB oil pick up The sump is longer and shallower so no need for the skid plate and works really well on street cars, I use them all the time now for any 1966 to 1971 B and E body B, RB or 426 Street Hemi motors I build I had one on my old pump gas Duster stoker motor, it ran as fast as 134.+ MPH at 9.993 ET in the 1/4 mile with no oiling issues as long as it had the oil level above the add mark before making a run, if I ran it at one quart low it would start to loose oil pressure about 200 ft after the finish line letting after letting off Summit oil pan part # G3511, Melling pick up part # 63-S4
Re: hemi oil pan
[Re: dragon slayer]
#3007051
01/20/22 12:39 AM
01/20/22 12:39 AM
Cab_Burge
I'll look in my 1969 Dodge FSM in the morning and see what they said the oil capacity was for the Street Hemi was when it was published: work: I don't remember ever hearing of a stock street hemi oil pan holding 6 quarts in them until 1970
Re: hemi oil pan
[Re: Cab_Burge]
#3007570
01/21/22 12:42 PM
01/21/22 12:42 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
My 1969 Dodge service manual does show 6 quarts oil pan capacity, I was WRONG It takes a big man to admit that , Cab. And a bigger man to admit it on the internet. I'm not even exaggerating when I say that you have forgotten more than I know about these things.
