Re: cam button
[Re: mopar dave]
#3005914
01/16/22 12:48 PM
01/16/22 12:48 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
None or nylon. Plenty of debate. The cam “shouldn’t” move forward
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: cam button
[Re: B3422W5]
#3005916
01/16/22 12:52 PM
01/16/22 12:52 PM
Posts: 4,684 Wichita
GY3
Wichita
I use the Comp Cams nylon one. You'll have to carve on it a little to get the fitment correct but it works great.
Re: cam button
[Re: mopar dave]
#3005926
01/16/22 01:21 PM
01/16/22 01:21 PM
B3422W5
Portage,michigan
Read on another thread Keith Black never used them building engines.
Re: cam button
[Re: B3422W5]
#3006030
01/16/22 08:40 PM
01/16/22 08:40 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
None or nylon. Plenty of debate. The cam “shouldn’t” move forward it won't with standard flat tappet lifters It can and will with rollers lifters
Re: cam button
[Re: mopar dave]
#3006054
01/16/22 09:25 PM
01/16/22 09:25 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
What holds the cam button in? Is it a press fit? the button sits in the recess between the 3 bolts, it can't fall out once the cover is bolted on. Should have .005-,010 clearance. Joe
Without Data, you’re just another guy with an opinion.
Re: cam button
[Re: B3422W5]
#3006244
01/17/22 04:01 PM
01/17/22 04:01 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Here is a thread I was involved in.......post 59 and 60 may be of some interest.... Cam buttons
Re: cam button
[Re: B3422W5]
#3006409
01/18/22 05:53 AM
01/18/22 05:53 AM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
All of the Hemi engines they built probably had a mechanical fuel injection pump driven by the gear drive. The hub for driving the pump was bolted onto the cam gear right where you would put a cam button. Iirc there were shims between that hub and the round cover to control cam thrust. Therefore a traditional cam button was not only impossible but also unneeded. The pump drive and gear drive cover served the same purpose. I have not had one of these apart for 45 years so I may have missed some detail but you get the drift. Injected engines would not/could not use a traditional cam button and didn't need one. Everybody else does.
