PLUMBERS - CPVC as dielectric coupling? #3005246
01/14/22 01:30 PM
01/14/22 01:30 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
It has been recommended to me that I use dielectric couplings on my water heaters to reduce corrosion. I suppose it is just a matter of price, but will a CPVC coupling do as a dielectric coupling? Don't expect to be sweating any joints near them.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Faust] #3005260
01/14/22 02:24 PM
01/14/22 02:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its not going to do anything to stop iron from rusting.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3005311
01/14/22 06:02 PM
01/14/22 06:02 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Is your house plumbed in copper or plastic?
The dielectric fittings are there to prevent galvanic corrosion between dissimilar metals. If your house is plumbed in copper pipe you don't want it in direct contact with the steel of the hot water heater. So the fitting electrically insulates the copper from the steel.
If your house is plumbed in plastic then dielectric fittings won't make any difference either way.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: PLUMBERS - CPVC as dielectric coupling? [Re: wingman] #3005347
01/14/22 08:39 PM
01/14/22 08:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Without knowing the answers to the questions that have been raised, all I can say is that if you are contemplating using female NPT PVC fittings, they are a leak waiting to happen.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3005371
01/14/22 09:52 PM
01/14/22 09:52 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: PLUMBERS - CPVC as dielectric coupling? [Re: wingman] #3005404
01/14/22 11:16 PM
01/14/22 11:16 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
The plumbing is all copper, but the nipples on the water heaters are steel. I seem to be getting a lot of corrosion (green copper) near the water heaters. I thought to just put a CPVC female/male coupling between the nipples and the copper. Could the green just be an excess of flux?
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Faust] #3005456
01/15/22 07:32 AM
01/15/22 07:32 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I don’t like copper directly fitted to steel. I use flexible stainless steel hoses. I don’t like the ones that are braided. They can have a reaction to the liner and put off black residue in your water. They are lots easier to change if you see a small leak. I would never use pvc or cpvc anymore. It’s probably against code in most places.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: fastmark] #3005474
01/15/22 10:21 AM
01/15/22 10:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've never known a plumber to clean a joint after soldering so the "green" could very well be from the solder. You can clean that off easily with a mild acid solution. The most effective is muriatic acid which will leave the copper as clean and shiny as the day it was made BUT be cautious with muriatic - the fumes are bad and it will burn skin. Dilute it and wear rubber gloves. Dip a rag in it and wipe the corroded area. Rinse with another rag soaked in clean water. The results are instant - no soaking and waiting required.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Faust] #3005479
01/15/22 10:32 AM
01/15/22 10:32 AM
PA
70Duster Offline
70Duster  Offline
PA
Quote
The green is either flux or a corrosion from a small leak. Just use teflon paste or tape and torque new copper threaded fittings onto the steel threaded fittings coming out of the water heater. The more fittings and different types of materials you use, the more opportunity there is for problems down the road. Never had an issue in four decades doing as described.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: 70Duster] #3005518
01/15/22 12:17 PM
01/15/22 12:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
How many foot/pounds are you recommending ??
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3005538
01/15/22 12:57 PM
01/15/22 12:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I use clear ammonia to clean solder joints after soldering to remove and neutralize any flux.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3005567
01/15/22 02:03 PM
01/15/22 02:03 PM
moparx Offline
moparx  Offline
Quote
crank it up 'till it strips or breaks, then back it off 1/2 a turn........................ biggrin [i couldn't help myself...... laugh2]
beer
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3005643
01/15/22 04:45 PM
01/15/22 04:45 PM
New Jersey
Dartforforty Offline
New Jersey
I have been a plumber for 35 years, and yes I wipe every solder joint. We have never met but now you know att least one plumber who takes pride in his work.
To answer the OP"s question, brass is a neutral metal which will not corrode when in contact with steel threads on a water heater.
I would not mix CPV with the copper as a dielectric union.
Ed
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Dartforforty] #3005649
01/15/22 05:10 PM
01/15/22 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Funny you should mention this - I was think this when I read the original post - most "threaded" connectors that copper solders into are brass. Yes, you can get copper, but brass are more common.
Re: PLUMBERS - CPVC as dielectric coupling? [Re: Stanton] #3006130
01/17/22 07:25 AM
01/17/22 07:25 AM
St. Louis, MO
BevoHoosier Offline
BevoHoosier  Offline
St. Louis, MO
Don't most new residential water heater installs opt for flex-hose lines anyway?
I just replaced an old water heater that had dielectric couplers on it and they were corroded solid anyway; just cut them off and sweated on normal fittings for the flex hose.
BMW 67 Dodge Polara 383
Re: PLUMBERS - CPVC as dielectric coupling? [Re: BevoHoosier] #3006133
01/17/22 08:09 AM
01/17/22 08:09 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It depends on the the age of the heater. The new ones I see have a galvanized steel nipple with a plastic liner on the inside already installed. Flex connectors install directly to those with none of the problems you are having. Before that came along, a good plumber used a brass nipple straight out of the tank.
