Re: PLUMBERS - CPVC as dielectric coupling?
[Re: Stanton]
#3005311
01/14/22 06:02 PM
01/14/22 06:02 PM
Posts: 3,393 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Is your house plumbed in copper or plastic?
The dielectric fittings are there to prevent galvanic corrosion between dissimilar metals. If your house is plumbed in copper pipe you don't want it in direct contact with the steel of the hot water heater. So the fitting electrically insulates the copper from the steel.
If your house is plumbed in plastic then dielectric fittings won't make any difference either way.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#3005347
01/14/22 08:39 PM
01/14/22 08:39 PM
Posts: 10,758 North Dakota
6PakBee
North Dakota
Without knowing the answers to the questions that have been raised, all I can say is that if you are contemplating using female NPT PVC fittings, they are a leak waiting to happen.
[Re: wingman]
#3005404
01/14/22 11:16 PM
01/14/22 11:16 PM
Posts: 2,417 Massachusetts
Faust
Massachusetts
The plumbing is all copper, but the nipples on the water heaters are steel. I seem to be getting a lot of corrosion (green copper) near the water heaters. I thought to just put a CPVC female/male coupling between the nipples and the copper. Could the green just be an excess of flux?
[Re: Faust]
#3005479
01/15/22 10:32 AM
01/15/22 10:32 AM
Posts: 1,643 PA
70Duster
PA
The green is either flux or a corrosion from a small leak. Just use teflon paste or tape and torque new copper threaded fittings onto the steel threaded fittings coming out of the water heater. The more fittings and different types of materials you use, the more opportunity there is for problems down the road. Never had an issue in four decades doing as described.
[Re: 70Duster]
#3005518
01/15/22 12:17 PM
01/15/22 12:17 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
torque new copper threaded fittings How many foot/pounds are you recommending ??
[Re: Stanton]
#3005538
01/15/22 12:57 PM
01/15/22 12:57 PM
6PakBee
North Dakota
I use clear ammonia to clean solder joints after soldering to remove and neutralize any flux.
[Re: Stanton]
#3005567
01/15/22 02:03 PM
01/15/22 02:03 PM
Posts: 19,615 north of coder
moparx
torque new copper threaded fittings How many foot/pounds are you recommending ?? crank it up 'till it strips or breaks, then back it off 1/2 a turn........................ ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) [i couldn't help myself...... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) ] ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Stanton]
#3005643
01/15/22 04:45 PM
01/15/22 04:45 PM
Posts: 712 New Jersey
Dartforforty
New Jersey
I've never known a plumber to clean a joint after soldering so the "green" could very well be from the solder. You can clean that off easily with a mild acid solution. The most effective is muriatic acid which will leave the copper as clean and shiny as the day it was made BUT be cautious with muriatic - the fumes are bad and it will burn skin. Dilute it and wear rubber gloves. Dip a rag in it and wipe the corroded area. Rinse with another rag soaked in clean water. The results are instant - no soaking and waiting required. I have been a plumber for 35 years, and yes I wipe every solder joint. We have never met but now you know att least one plumber who takes pride in his work. To answer the OP"s question, brass is a neutral metal which will not corrode when in contact with steel threads on a water heater. I would not mix CPV with the copper as a dielectric union. Ed
[Re: Dartforforty]
#3005649
01/15/22 05:10 PM
01/15/22 05:10 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
brass is a neutral metal which will not corrode when in contact with steel threads on a water heater. Funny you should mention this - I was think this when I read the original post - most "threaded" connectors that copper solders into are brass. Yes, you can get copper, but brass are more common.
[Re: Stanton]
#3006130
01/17/22 07:25 AM
01/17/22 07:25 AM
Posts: 388 St. Louis, MO
BevoHoosier
St. Louis, MO
Don't most new residential water heater installs opt for flex-hose lines anyway? I just replaced an old water heater that had dielectric couplers on it and they were corroded solid anyway; just cut them off and sweated on normal fittings for the flex hose.
BMW
67 Dodge Polara 383
