I've used 9.3 to 1 on CA pump swill on a 484 C.I. Mega block blown pump gas street 426 type Hemi, it made 930 at 7300 RPM with 7.5 lbs of boost (12% underdriven) with 33 degrees BTDC total timing using a MSD7AL3 ignition
We switch pulleys and switch to C14 race gas and reduce the total timing to 25 BTDC and it made 1027 HP at 6500 RPM with 12.0 lbs. of boost before going into detonation
I should have tried 20 degrees first and went from there
That was with a BDS 10:71 blower and 2 1050 CFM Carb Shop blower Dominator carbs.
ITHS
