I'm old school and want to learn about G3 Hemis #3003421
01/09/22 12:34 PM
01/09/22 12:34 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I have done lots of cars with carbureted big and small block motors.
I bought a 67 Dart project car and it came with a 5.7 gen3 Hemi.
I am interested in learning about the Hemi so I can make the swap in the Dart but I know very little about the motor and the systems needed to make it run.
Does anyone know of any good books that will explain the workings of the motor and what systems I need? I need something like "Hemis for Dummies"!
I don't mind looking at stuff online but I would like to find some kind of books.
Any ideas?
Thanks in advance for your help!
Re: I'm old school and want to learn about G3 Hemis [Re: patosmith] #3003466
01/09/22 02:28 PM
01/09/22 02:28 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
It's not just hemis any new motor using fuel injection uses sensors/computers(transmissions also) to run it. Depending on what you plan on putting in and what trans, carbed or efi is what you need to learn about. You can use a modern hemi and convert it to carb/ distributor ignition if you wanted.
Re: I'm old school and want to learn about G3 Hemis [Re: patosmith] #3003693
01/10/22 02:14 AM
01/10/22 02:14 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
There was a swap book, "New Hemi Engine Swaps: How to Swap 5.7L & 6.1L Hemi Engines into Almost Anything" by Joe Hinds, but it is out of print. You could look around and see if you can find it. There are several Gen 3 Hemi engine building books available:
https://www.amazon.com/How-Build-He...ef=pd_lpo_1?pd_rd_i=1613254105&psc=1
https://www.amazon.com/New-Hemi-Engines-2003-Present-Rebuild/dp/1613254474
https://www.amazon.com/Hemi-Engines-2003-Present-How/dp/1613253575
Some online Gen 3 Hemi engine articles:
https://www.enginebuildermag.com/2019/08/unlocking-the-mysteries-of-the-5-7l-gen-iii-hemi/
https://www.dodgegarage.com/news/ar...engine-quick-reference-guide-part-i.html
https://www.dodgegarage.com/news/ar...-hemi-quick-reference-guide-part-ii.html
There was a Gen 3 Hemi swap series on a Dart in Mopar Connection online magazine that may be helpful: https://moparconnectionmagazine.com/the-ultimate-a-body-hemi-swap-guide-with-project-orange-crush/
Holley has a lot of good information and comprehensive swap systems. They just added 1973-1976 A bodies. I suspect the earlier A bodies, like your Dart, will be added soon: https://www.holley.com/products/engine_swap_parts/hemi_swap_systems/
DIY Hemi is also a good site for harness and ECM info: https://www.diyhemi.com/
Another excellent harness and ECM site is hotwire at: https://www.hotwireauto.com/
This is just scratching the surface. Lots of knowledgeable folks have posted swap info on this site as well.
Re: I'm old school and want to learn about G3 Hemis [Re: patosmith] #3004063
01/11/22 10:11 AM
01/11/22 10:11 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
NMCA NSS 67 Coronet
Re: I'm old school and want to learn about G3 Hemis [Re: Barry70GTX] #3004168
01/11/22 03:01 PM
01/11/22 03:01 PM
P
P
Thanks everyone!
I'm more interested in learning about the Hemi more than I am about the swap.
Things like sensors, VVT things like that.
I will look threw the stuff everyone posted and start learning.
I don't know what trans I will use. I have a 904 but I want to run something with overdrive and still fit in the tunnel without much modification.
The car won't be raced but I want the Trans strong enough to handle around 400-450 HP.
I have a spare 8 3/4 that I plan to use in place of the 7 1/4.
Thanks again for your help!
