Big Block Fuel pump Pushrod length? #300323
04/26/09 06:44 PM
04/26/09 06:44 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Could anyone tell me the exact length of the Fuel Pump Push rod (New, unused) in a 440 block?
Also, approx. how high is the lobe on a B/RB cam that actuates the lever on the fuel pump? (Oh yeah, something's very worn...)
Thanks guys!
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Big Block Fuel pump Pushrod length? [Re: Hoof Hearted] #300324
04/26/09 09:35 PM
04/26/09 09:35 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I don`t have the length for you but it is very common for the push rod to wear.
Re: Big Block Fuel pump Pushrod length? [Re: Hoof Hearted] #300325
04/26/09 09:59 PM
04/26/09 09:59 PM
South Western Michigan
gkellycuda Offline
gkellycuda  Offline
It happened to my ole'-man's 383 too..
Took us a while to figure out what was going on, until I posted on this site a few years back and someone came back with in minutes with the answer. Very common...
1999 Dodge 3/4ton Cummins 24 Valve, 4x4
Re: Big Block Fuel pump Pushrod length? [Re: mopars4ever] #300326
04/27/09 12:20 AM
04/27/09 12:20 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
3.25
Re: Big Block Fuel pump Pushrod length? Updated... [Re: 1_WILD_RT] #300327
04/27/09 12:31 AM
04/27/09 12:31 AM
S.E. Conn
S.E. Conn
Thanks!!
Mine is worn about 1/8" on the cam end and is also concaved; Is this 1/8" loss enough to make my fuel pump not work?
2005 300C Hemi
Re: Big Block Fuel pump Pushrod length? Updated... [Re: Hoof Hearted] #300328
04/27/09 02:24 AM
04/27/09 02:24 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You've lost 1/8th" of pump travel & it started with probably 3/8th" so you've lost 30% if the pumps delivery curve is consistant.. If it spikes after a point than you could be off by 50% or more...
