'67 B EFI FUEL TANK #3003022
01/07/22 09:29 PM
01/07/22 09:29 PM
West Palm Beach, Florida
Copper Dart Offline OP
I've been waiting for a EFI ready oem style fuel tank for my 1967 Satellite since June of 2021!
No estimate when they will be available as of today. What are the pro's and con's of EFI fuel pumps frame rail mounted verse in tank? Thanks
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003039
01/07/22 10:01 PM
01/07/22 10:01 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
a buddy of mine put a 318 magnum in a 37 chrysler and a 49 plymouth. on the 37, he used the a frame mounted ford f150/bronco hi pressure pump and has no problems with it. on the 49 he found that a jeep grand cherokee( i think, may have been reg cherokee) tank fit between the frame rails. hope this helps
Re: '67 B EFI FUEL TANK [Re: trw1982] #3003044
01/07/22 10:14 PM
01/07/22 10:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just wait til the tank gets low and you go around a corner. Pump sicks air as the fuel sloshes away, engine instantly stops running. At least put one of those Holley Hydramat socks on the end of the pickup.
Re: '67 B EFI FUEL TANK [Re: Sniper] #3003049
01/07/22 11:09 PM
01/07/22 11:09 PM
Andrewh Offline
Andrewh  Offline
yeah, that is the issue.
it falls flat if the pick up gets uncovered.
I went with a surge tank instead of cutting up a new tank or ordering another.
http://www.robbmcperformance.com/products/powersurge.html
this one includes the pump so it is a pretty good deal.
I didn't use that one, because I didn't know about it when I bought mine.
I used this one.
https://www.usrallyteam.com/index.php?main_page=product_info&products_id=1524
but it doesn't come with a pump.
I also don't recommend it, because it is a pain to put together and take apart.
This does mean you need 2 pumps, not just 1 however.
you need a pump to feed the surge tank.
I put mine together so if one of the 2 failed, I could replumb the system to at least limp me home.
now most want you to mount it in the engine compartment.
I put mine above the rear axle instead. both the feed pump and the surge tank.
I suppose mine is skinny so it lends itself better to that.
there is another cheaper one, but it is made out of plastic. bothered me a little so I don't think I bookmarked it.
but there isn't any pressure in the tank, so it really doesn't matter. Just a personal choice.
I was wrong, isn't cheaper,
https://www.summitracing.com/parts/...Jo0jlbuwnBIH2cIbPjb8tK_x85BoClVYQAvD_BwE
name branded though.
they wanted you to be able to use the original mechanical fuel pump to feed it and it would feed the efi setup if I recall correctly.
Re: '67 B EFI FUEL TANK [Re: Andrewh] #3003051
01/07/22 11:16 PM
01/07/22 11:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I am fuel injecting my 51 Plymouth. I am going this route
https://madscientistmatt.blogspot.com/2005/12/surge-overkill.html
Using the stock mechanical pump to feed the surge tank, and putting the EFI return back there are as well.
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003094
01/08/22 08:27 AM
01/08/22 08:27 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Waited five months for my Aeromotive tank to show up for a 71 e body. Finally got it, pulled it outta the box, bottom side is scratched like.someone manhandled it on a work bench. Back it goes for another who knows how long.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: '67 B EFI FUEL TANK [Re: Sniper] #3003163
01/08/22 02:08 PM
01/08/22 02:08 PM
moparx Offline
moparx  Offline
the needle valve, check valve, and other plumbing on the top of the filter housing. looks like 3/8 NPT ?
TIA ! bow
beer
Re: '67 B EFI FUEL TANK [Re: moparx] #3003169
01/08/22 02:15 PM
01/08/22 02:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
TIA ! bow
beer
He's going over kill. All I am doing is getting one of those remote spin on filter adapters, using a long fuel filter that fits it and the pickup tube idea.
My adapter has 4 ports, two in and two out. One for fuel in from the mechanical pump, one for fuel out to the EFI fuel pump, one for fuel return from the regulator into the adapter and the fourth is the line back to the tank for the excess.
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003171
01/08/22 02:22 PM
01/08/22 02:22 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
What tank are you looking for? Summit shows 4 of the Tanks Inc. TCR14-T in stock. Have used this tank on 2 cars and they work good.
The only Carbs I care about are under the hood!
Re: '67 B EFI FUEL TANK [Re: Azzkikrcuda] #3003298
01/08/22 10:14 PM
01/08/22 10:14 PM
Yes, I did see those without pump modules. What fuel pump and sending unit do you use for that tank? I didn't see any references like "must use fuel pump part # and sending unit #"
Copper
Mom.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003334
01/09/22 12:18 AM
01/09/22 12:18 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003507
01/09/22 04:58 PM
01/09/22 04:58 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Go to Tanks website and pick out the sender and fuel pump you want, then put those part numbers in on Summits website. GPA-2 fuel pump if under 450 HP, GPA-4 for up to 630 HP and TAN-ORG fuel level sender for mopar. Holley also sells this tank/pump/sender bundle under PN#19-183
Spectra used to make an EFI conversion tank that the pump module went in the side on the tank like the stock sending unit for the 66-67 cars but I don't see it listed. Have used this tank for a few lower HP builds and it works good other then the fuel level ohms are not right for Mopar.
Re: '67 B EFI FUEL TANK [Re: Azzkikrcuda] #3003615
01/09/22 09:34 PM
01/09/22 09:34 PM
The Holley setup was what I was hoping for being that for I'm going to be switching from QuickFuel carburetor to a Sniper Injection System. I didn't see any savings on purchasing all the necessary parts separately anyway. Hoping that supply issues clear up soon enough.
So no mention of the pros and cons of in tank vs frame rail mounted pumps for EFI systems for street use.
Copper
Mom.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: 65 Hemi] #3003622
01/09/22 09:41 PM
01/09/22 09:41 PM
Originally Posted by 65 Hemi
Thanks $580 Shipped is a good price!
I know nothing about any of these three fuel tank choices good or bad so I was leaning toward the Holley because of the Sniper EFI System that I plan of using. Please advise if you feel qualified. Just thinking about it further, using the Holley and Spectra style pumps only seem a better choice because of serviceability. It looks as if the Holley and Spectra fuel pump modules are generic fit not custom for a '67 B body tank. The Aeromotive looks like OEM tank on the outside but modified for a EFI pump and baffle and would be my choice if function and reliability are equal for my application. Again, I know next to nothing about them. Thanks
Copper
Mom.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3003628
01/09/22 09:47 PM
01/09/22 09:47 PM
Is a fuel pressure regulator required on these fuel tank/pump sets when used on Sniper or Atomic EFI systems? I will like to somehow incorporate a fuel return also.
Copper
Mom.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: 65 Hemi] #3003641
01/09/22 10:19 PM
01/09/22 10:19 PM
Andrewh Offline
Andrewh  Offline
I had mine mounted on the rail low for a while.
as said before, if the tank ran low, it would fall over.
the other issue was, the guy that ran my exhaust put it really close to the pump.
no issues normally, but we went to see christmas lights one year and it was stop and go traffic for over an hour or two. the pump overheated and wouldn't put out enough pressure and my car stalled in the line up of cars. was lucky and there was a place to push it out of the traffic.
couldn't figure it out, but sitting there it cooled enough to get it running again, and I flew out of there to get it home, since I didn't know what it was.
finally figured it out after a bit of trouble shooting, and decided to move it and do the surge tank at the same time.
Re: '67 B EFI FUEL TANK [Re: Andrewh] #3003644
01/09/22 10:30 PM
01/09/22 10:30 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Yes you need a regulator efir or carb. I run a 340lph Stealth tank in my 68 GTS and regulate it to 20 psi for the main fuel rail and again down to 5.5 for the carb and n20. The cool part is I can swap the regulator and go EFI when the time comes.
Re: '67 B EFI FUEL TANK [Re: Jeremiah] #3004201
01/11/22 04:50 PM
01/11/22 04:50 PM
Jeremiah do you recommend the Aeromotive tank? Any opinion on the Holley or Tanks fuel tanks? Thanks
Copper
Mom.
Ricky Valdes
Re: '67 B EFI FUEL TANK [Re: Copper Dart] #3004255
01/11/22 06:07 PM
01/11/22 06:07 PM
Jamey Offline
Jamey  Offline
I have a Tanks and it works just fine.
