What RPM would you shift?
#3002637
01/06/22 04:21 PM
01/06/22 04:21 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I got some numbers for my new toy and was trying to figure out how to best get it down the track. 5200 lbs with driver. 5 speed auto. 1st: 3.587 2nd: 2.186 3rd: 1.405 4th: 1.0 5th: 0.831
26" rear tire. 2.65 rear gear.
Would you ride the HP plateau or reach farther back and grab a bucket load of that torque?
Unfortunately, it'll be a little while before I can try it out at the track.
Re: What RPM would you shift?
[Re: feets]
#3002640
01/06/22 04:26 PM
01/06/22 04:26 PM
Posts: 4,457 Washington
madscientist
Washington
If you want to go fast run the RPM up.
[Re: madscientist]
#3002642
01/06/22 04:41 PM
01/06/22 04:41 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
[Re: feets]
#3002649
01/06/22 05:12 PM
01/06/22 05:12 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
lots of TQ, is that with the EFI intake you showed me , same heads ? very good, that should move that heavy car
[Re: feets]
#3002681
01/06/22 06:28 PM
01/06/22 06:28 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
That must be the latest supercar (Mercedes, wasn't it?)
Rich H.
Esse Quam Videri
[Re: feets]
#3002707
01/06/22 08:25 PM
01/06/22 08:25 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
Take it to a 1/4-mile track and test shifting it at 4500, 5000, 5500 and 6000 RPM, then look at all the incremental numbers and decide what RPM worked the best If it went fastest shifting at 6000 RPM try 6300, and then 6600 RPM, you need to find out what the car likes for the best results
[Re: furious70]
#3002734
01/06/22 09:50 PM
01/06/22 09:50 PM
feets
Senior Management
Senior Management
Irving, TX
9 GRAND AND DON'T LOOK BACK AMEN BROTHER! This is my Mercedes CL65. Bone stock. I'm changing the turbo bypass valves this weekend. That will allow us to tune the V12. The boost will be a bit higher and hold on longer. Most tunes add 100-110 torque and 60-70 hp. The torque will be hard to hold since it already lights the tires at 50 mph. However, it's the torque that makes the car so nice. 60-130 mph locked in 4th gear took 10.2 seconds. The best it has turned using second and third gears was 6.9 seconds. Not too shabby for an old pig boat. As for my 541 build, it's waiting on me to wire and plumb the EFI.
[Re: feets]
#3002795
01/07/22 06:54 AM
01/07/22 06:54 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Most times at the track you ‘take it too the max’... You can feel the ‘drop-off’ if you go past peak power... Never found that ‘short shifting’ ever worked for me? Saves the engine but kills the ET, (phone home) lol...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: feets]
#3003238
01/08/22 06:21 PM
01/08/22 06:21 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
In theory, maximizing the hp under the hp curve should yeild the best et and mph. This theory works well with my cars, but I have a stock torque converter. I think this theory breaks down with higher stall race converters when the motor is back into the converter at the shift recovery rpm. The cam LSA and ICL probably play a part as well, and mine are not conventional..
Your shift/shift recovery rpm ratios are 0.61, 0.64, and 0.71 for 1-2, 2-3, 3-4 gear changes respectively.
With that, assuming you have a tight converter, I'm in the 5700-5800 camp at least for 1-2, and maybe 2-3. The 3-4 shift.might be 5400-5500. That's just eye-balling the graph and pushing the shift recovery hp up close to the shift hp.
This has played out pretty well on both motors I had in my charger with a torqeflite (0.59 and 0.69) . My 508 peak power was about 5600, but after a bunch of track testing, I shift 1-2 at 6500, and 2-3 at 6200.
[Re: TheOtherDodge]
#3003434
01/09/22 01:08 PM
01/09/22 01:08 PM
feets
Senior Management
Senior Management
Irving, TX
I took it out for the last run of the 2021 Texas Muscle Car Club Challenge. It was an 1/8 mile whice is NOT where this thing belongs. I was surprised the Michelin PS4S hooked as well as they did. It had to be in the track prep. I left it in auto with sport on and ESP off. About 300 feet out it hazed he tires for a couple seconds. Naturally, it starts to feel good at the shift into third at 80 mph and speed builds rapidly but the 1/8 comes up quickly. I was lined up next to a Challenger 1320 on stickies. He sent me home by a tenth and a half but I felt good about having 2 mph on him. This thing is an awesome highway cruiser but it's short game is week.
