Re: 5/8" wheel studs
[Re: lancer493]
#3001484
01/03/22 01:18 PM
01/03/22 01:18 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Finding a shop in your area willing to do it is likely not gonna be easy . We have sent a couple pairs back to Strange to get done. Not all that expensive other than shipping..And yes it should be done on almost every drag car IMO
[Re: Al_Alguire]
#3001505
01/03/22 01:39 PM
01/03/22 01:39 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I broke my 1/2 studs years ago and they were only a year or so old, I have Mark Williams Axles I sent them to them they installed 5/8 studs and reheat treated the axles it wasn't much at all a couple hundred maybe , I haven't had a problem since. I had the Holeshot wheels custom made for my application last year and one of the options was having the stud holes made for 5/8 studs which I had done.
[Re: lancer493]
#3001576
01/03/22 03:50 PM
01/03/22 03:50 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Ran a heavy 9 sec car using a brake for years never had any issues with 1/2 studs. Must have just been lucky
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3001595
01/03/22 04:13 PM
01/03/22 04:13 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
My understanding is that drag radials are much harder on the studs as well.
When I moved to a Dana in my car I went ahead and jumped up to the larger stud.
68 Barracuda Formula S 340
[Re: lancer493]
#3001651
01/03/22 04:32 PM
01/03/22 04:32 PM
Posts: 17,888 S.E. Michigan
ZIPPY
S.E. Michigan
If you all could draw a line in the sand and say "this is really the point you need 5/8 studs", what would it be?
(Other than "just broke the 1/2", now it's time")
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3001673
01/03/22 05:36 PM
01/03/22 05:36 PM
Bad340fish
Tulsa OK
I'd say whenever you upgrade axles or rear end go ahead and upgrade, especially on a radial. Its the best and cheapest time to do it. Also most of us don't ever plan to make our cars slower, sure it happens but rarely on purpose.
[Re: Bad340fish]
#3001800
01/03/22 11:22 PM
01/03/22 11:22 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would do it on any drag race rear or when specing axles. Small to no extra cost on new parts. So much nicer.
Need? 10s, 1.50 60', >2500#, transbrake, clutch, >600HP, and/or radials. It's one of those decisions that's really a no brainer.
[Re: dvw]
#3001872
01/04/22 09:12 AM
01/04/22 09:12 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
ounce of protection = pound of cure
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#3001884
01/04/22 09:54 AM
01/04/22 09:54 AM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Remember that an improperly torqued stud will be much more susceptible to breaking than a properly torqued stud - both loose and too tight.
Me - I run 11/16 Mark Williams studs. But the threads are 5/8.
[Re: markz528]
#3001912
01/04/22 11:20 AM
01/04/22 11:20 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I ran 1/2" studs on my cuda for several years w/ no problems. 3800 lbs on drag radials running mid 9s. Footbraking 1.32 sixty foots. I upgraded to 5/8" studs when I added nitrous. Now it twists 35 spline axles instead, lol.
[Re: an8sec70cuda]
#3001947
01/04/22 01:15 PM
01/04/22 01:15 PM
Posts: 19,488 north of coder
moparx
stoopid old man question of the day.......... when going with 5/8" studs, how does one modify the wheel ? if the wheel has a "cone seat" style lug nut, just drilling the hole to 5/8" and using a 5/8" "flange nut" will work ? if the wheel has an 11/16 "shank style" nut, does one need a piece of 1/32" wall tubing to take up the difference ? do you need to use "hub centric" rings for the difference in diameter between the wheel center hole and the axle hub diameter ? i have often wondered about what else may need to be done when using 5/8" studs, but never asked. try not to beat on me too bad for asking.
[Re: moparx]
#3001967
01/04/22 01:43 PM
01/04/22 01:43 PM
ZIPPY
S.E. Michigan
I'll also raise my hand just as a clueless idiot, without any age references....
Every vehicle I've seen them on had aftermarket lug centric wheels.
(Which is okay and all, unless the stock look is desired)
Rich H.
Esse Quam Videri
[Re: moparx]
#3001997
01/04/22 02:39 PM
01/04/22 02:39 PM
markz528
Morrow, OH
stoopid old man question of the day.......... when going with 5/8" studs, how does one modify the wheel ? if the wheel has a "cone seat" style lug nut, just drilling the hole to 5/8" and using a 5/8" "flange nut" will work ? if the wheel has an 11/16 "shank style" nut, does one need a piece of 1/32" wall tubing to take up the difference ? do you need to use "hub centric" rings for the difference in diameter between the wheel center hole and the axle hub diameter ? i have often wondered about what else may need to be done when using 5/8" studs, but never asked. try not to beat on me too bad for asking. I agree all the 5/8 studs I have seen were on aftermarket wheels. Yes - there is a tube to make up the difference if a true 5/8 stud. Many now (including mine) have the 11/16" shank so no tube is required. Pretty much with this setup you are lug centric not hub centric so no hub adapter.
[Re: markz528]
#3002002
01/04/22 02:57 PM
01/04/22 02:57 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The thread on sleeve style studs are basically long bolts threaded full length that the sleeve then screws over, locking the bolt and providing the proper wear surface for the wheel. I have used them, but avoid them now. Mostly because they are a PIA to use as opposed to a true machined double ended stud. Most aftermarket flat seat race wheels have 11/16" holes. I've had to lightly hone wheels in the past when using the sleeve style.
If you insist on using 1/2" studs, at least use decent, US made parts. I've seen studs made from Chineseium that broke and really shouldn't have.
[Re: CMcAllister]
#3002127
01/04/22 09:20 PM
01/04/22 09:20 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
5/8" studs are just a better deal all around. I do have one car that came with bent 5/8 studs in the Dana however it was heavier and running low 9's leaving on the bumper. The brand of studs is unknown.
You definitely want to send the axles out to drill and tap them for 5/8. Those axles are HARD! I would not want the bill for a bunch of burned up mediocre tooling at a local shop.
Also take your brakes into account especially if you have disc. It might be wise to send the rotor hats in for modification as well. That or use a step bit..maybe a reamer if you have access to a mill.
