'70-71 Air Grabber air cleaner id? #300094
04/26/09 01:11 PM
04/26/09 01:11 PM
NY
70440+6bbl Offline OP
NY
I need an air grabber air cleaner assembly for a '71 GTX 440 4bbl. What is the difference in height from the 383 base?
Re: '70-71 Air Grabber air cleaner id? [Re: 70440+6bbl] #300095
04/26/09 04:07 PM
04/26/09 04:07 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Easiest way to tell:
The 383 base will rest on the carb base when placed on a flat surface.
The 440 base will have the carb base not touching the flat surface the assembly is resting on.
Re: '70-71 Air Grabber air cleaner id? [Re: 1fastrunner] #300096
04/26/09 09:22 PM
04/26/09 09:22 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I think the 383 base is 3/8" taller. ?
Re: '70-71 Air Grabber air cleaner id? [Re: 70440+6bbl] #300097
04/27/09 11:46 AM
04/27/09 11:46 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
HEIGHTS FROM BOTTOM OF CARB NECK TO TOP OF CROSSBAR
1969 383 3 1/2”
1969 440 3"
1970-1972 383-400 2-1/2"
1970-1972 340-440 2"
WHEN PLACED ON A FLAT SURFACE THE 69 383 BASE WILL SIT ON THE CARB NECK
Re: '70-71 Air Grabber air cleaner id? [Re: TONY_DAGOSTINO] #300098
04/27/09 01:55 PM
04/27/09 01:55 PM
NY
NY
Thanks for the help guys/Tony
