Best 383 street pistons? #3000366
12/31/21 04:51 PM
12/31/21 04:51 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
What are the best Pistons for street use in a 383 using pump gas? Just a mild build using 516 heads or maybe 452. Cam choice is about 220@050 with dual plane weiand intake and 440 source distributor. This will go into a B body or maybe a pickup truck. Thanks Mopar lovers!
Re: Best 383 street pistons? [Re: PowerWagonDude] #3000389
12/31/21 05:33 PM
12/31/21 05:33 PM
AndyF Offline
AndyF  Offline
Check Icon, they had some higher compression 383 pistons available for awhile, not sure if they still stock them or not.
Re: Best 383 street pistons? [Re: AndyF] #3000584
01/01/22 11:53 AM
01/01/22 11:53 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
speed-pro 2315 is probably the best general use piston. reality is that there are other options for a more specific build but if i was looking for a reliable easy install piston the 2315 would be hard to beat. i like hyper pistons for street use, beat the snot out of them without issue, but you must follow the instructions in the literature. i don't think you need a high dollar piston.
Re: Best 383 street pistons? [Re: lewtot184] #3001010
01/02/22 06:38 AM
01/02/22 06:38 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno on Icon pistons, but KeithBlack offers for sure hypereutectic pistons for 383. Even domed as far I recall. They use to be found on $350-400 rate shipped. That's not a huge invest over stock replacements and way less than forged units rated on $600-700
Re: Best 383 street pistons? [Re: PowerWagonDude] #3001082
01/02/22 12:34 PM
01/02/22 12:34 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The ICON 687KTD is likely the best "Forged" performance piston for the price.
ICON 687KTD 1.912" CH, -4.5cc valve/dome, 674 grams 1/16", 1/16", 3/16" ring pack. $664.99 (price includes piston rings)
https://www.summitracing.com/parts/uem-ic687ktd-030
This has a slight dome, but overall compression is not that high. with a 84cc head like an Edelbrock or open chamber stock head (usually > 84 cc chamber) and a 0.040" head gasket, compression ratio is only about 9.5:1
The Diamond 51900 is a real nice forged flat top piston, but also expensive at $1086.62 (price includes piston rings)
1.916" CH, and 4cc valve reliefs, so compression around 8.8482:1. Using a 0.020" head gasket bumps compression to around 9.2339:1
This would be a good choice if using heads with < 80 cc chambers.
https://www.summitracing.com/parts/dpp-51900-8
The KB Hypereutectic are slightly less expensive (most listed prices do not include piston rings), but use the wider 5/64", 5/64", 3/16" ring pack
The KB 400 is sort of like the ICON 687, but compression height is less at 1.908", and dome is a bit larger so -6cc overall chamber difference. Overall the compression ratio is just a tad higher than the ICON 687. My sample calc = 9.5298:1 compared to the IC 687 = 9.4793:1
At only $376.99 This would be the best piston for the cost. For a mild build like yours, this would be a good choice if using head with 80+ cc chambers.
https://www.summitracing.com/parts/uem-kb400-030/make/dodge
The KB 162 is a Flat Top piston. 1.908" CH, 5cc valve reliefs, so lower compression around 8.6131:1. 0.020" head gasket, around 8.995:1
The Compression ratio(s) assumes Block height of 9.980", 4.28" bore (0.030" over), 3.380" stroke, 6.358" rod, 9.764cc head gasket volume (about 0.040" thick), 84 cc cylinder head volume
The Speed-Pro 2315 would be the highest compression "Flat Top" piston, and is likely the heaviest piston choice. The lack of valve reliefs is not an issue with mild cams, but can be a problem with larger camshaft profiles.
CH is 1.920, and using same assumptions above Compression ratio = 9.2499:1
The Speed pro is $445.99 without rings, and rings might add another $100+ so around $100 less than the ICON piston, but the ICON had many more performance features.
Re: Best 383 street pistons? [Re: 451Mopar] #3001142
01/02/22 02:44 PM
01/02/22 02:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
dunno on shipping thought
https://www.cnc-motorsports.com/kei...bb-chrysler-383-dome-6cc-bore-4-250.html
Re: Best 383 street pistons? [Re: 451Mopar] #3002164
01/04/22 10:59 PM
01/04/22 10:59 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The Icon 687 has a net positive dome volume and will give a 0.5 higher compression ratio than the KB400 which has a net zero dome volume. Both decent choices as is the 2315.
Re: Best 383 street pistons? [Re: NachoRT74] #3002460
01/05/22 11:35 PM
01/05/22 11:35 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
UEM makes several lines of pistons: Keith Black, ICON, Silvolite. I've used many sets of KB pistons and Silvolite too when on a budget and have had good success with all of them.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Best 383 street pistons? [Re: BigDaddy440] #3002485
01/06/22 03:58 AM
01/06/22 03:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I know UEM makes all those, I'm KB user. I just don't know the options from ICON, because they are never on my budget, so never search for them LOL.
Re: Best 383 street pistons? [Re: BSB67] #3003075
01/08/22 03:39 AM
01/08/22 03:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
2315 don't like valve float smile
