Carburetor Doesn't Fit Engine #2999428
12/29/21 10:41 AM
12/29/21 10:41 AM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Good morning. I have a stock cast 1971 intake and my 4737 Carter AVS with a car gasket 60123 rocks on top of the 53 choke of my 1970 Plymouth GTX. Any ideas now to fix this? I have a N96 hood.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Carburetor Doesn't Fit Engine [Re: GTXKARL] #2999456
12/29/21 11:44 AM
12/29/21 11:44 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
got a picture? holley choke mechanisms are different than carters. thick insulator gasket may help.
Re: Carburetor Doesn't Fit Engine [Re: GTXKARL] #2999540
12/29/21 02:38 PM
12/29/21 02:38 PM
What motor are you working on?
1970-71 383 had Holley czrbs,440 HP had AVS carbs shruggy
340 had Thermobogs shruggy
Re: Carburetor Doesn't Fit Engine [Re: Cab_Burge] #2999661
12/29/21 08:06 PM
12/29/21 08:06 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi it a 440 engine
Re: Carburetor Doesn't Fit Engine [Re: GTXKARL] #2999672
12/29/21 08:35 PM
12/29/21 08:35 PM
Chicago
PurpleBeeper Offline
Chicago
Please show us a picture of where the clearance problem is. I think the 4737 carburetor is the original carb on a 1970 440 with a 4-speed, so it "should" fit....but apparently isn't.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Carburetor Doesn't Fit Engine [Re: PurpleBeeper] #2999684
12/29/21 08:49 PM
12/29/21 08:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
He says he has a 71 intake, not sure if that should matter though.
Re: Carburetor Doesn't Fit Engine [Re: Sniper] #2999691
12/29/21 09:13 PM
12/29/21 09:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect he has the wrong choke housing. I believe he needs the one that was flat on top, but probably has one with the slight bulge. If that is right, he needs to lift the carb off the intake about a 1/4" or replace the incorrect parts.
The choices are, the correct choke with the flat plate, or the thicker carb gasket, or the AVS with the extended throttle shafts.
Re: Carburetor Doesn't Fit Engine [Re: poorboy] #2999851
12/30/21 11:37 AM
12/30/21 11:37 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have an NOS Carter choke for 70 440 if you are needing one PM me.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
