Re: Manual Transmission Gearing Question
[Re: Sniper]
#2998747
12/26/21 11:51 PM
12/26/21 11:51 PM
Posts: 11,508 delivering your oil
nutso suave
delivering your oil
Sniper - I’m not sure what the ratios are in my transmission…I know it’s the version with a flipped shift linkage and that’s about all. I’m curious to know what the ratios might be so I can figure out what gear ratio would be ideal for the rear end.
Edit: I found this on allpar, not sure if there were more options/combinations out there.
Edit 2: this may be what I have…the 74-75 ratios. It isn’t overdrive but I’m not sure how that worked, if all the later transmissions used the flipped linkage. Hmmm.
[Re: Moparteacher]
#2998853
12/27/21 01:38 PM
12/27/21 01:38 PM
Posts: 6,326 nowhere
Sniper
nowhere
FWIW, There are 2 OD gear ratios for that transmission, and the speed gears and counter gear are NOT interchangeable. The gear sets have different pitches. The common Dodge/Plymouth A833OD has a final gear ratio of .73:1. The other version has a final gear ratio of .71:1 (if memory is correct),........or maybe it was .69:1..........Hmmmmm?
I put one in my RR with 4.88s.
I keep hearing this but never see proof. Why would Chrysler make a different set of gears for an infinitesimal difference in ratio? I will admit though, my my OD era parts manuals are thin.
[Re: Sniper]
#2998919
12/27/21 04:02 PM
12/27/21 04:02 PM
Posts: 1,849 South Bend
John Brown
South Bend
I keep hearing this but never see proof. Why would Chrysler make a different set of gears for an infinitesimal difference in ratio? I will admit though, my my OD era parts manuals are thin. They were also sold to GM for use in trucks.
[Re: nutso suave]
#2999018
12/27/21 09:16 PM
12/27/21 09:16 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
You can verify the ratios with the tranny out of the car or in the car by marking the front driveshaft yoke and the tail shaft housing and having the rear wheels off the ground, remove all the spark plugs and have someone rotate the crankshaft one full rotation with the tranny in the O.D. gear and count the driveshaft revolutions. It should rotate one full revolution and right at 10% (.09) more You can verify any gear ratio by using this method, same thing on the rear end ratio, turn the wheels one full revolution with a posi and count the number of pinion yoke revolutions, if the yoke turns 4 and a little bit more it is 4.10, if it rotates 4 and 1/3 it is a 4.30 ratio, if 3 1/4 it is a 3.23 ratio and so on
