Holley Hyperspark for Sniper
#2998340
12/25/21 10:52 AM
12/25/21 10:52 AM
Posts: 1,385 Az
69hemibeep
Az
Anyone running the Hyperspark ignition and what do you think of it? I'm considering it for a project.
1969 Hemi Roadrunner 2nd owner
Re: Holley Hyperspark for Sniper
[Re: 69hemibeep]
#2998380
12/25/21 01:33 PM
12/25/21 01:33 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
I've got the entire setup on my 512. No more springs or slotted plates to screw around with in the distributor. You can make basic timing changes right on the handheld or use the tuning software to make more advanced changes. Installation was straight forward as well with the premade harnesses and clear cap to set the distributor. Only issue you may have is the head may need a little clearance work to clear the distributor. My Edelbrocks did.
Andy has an article in Hot Rod detailing the Hyper Spark install.
