Tubes #2998275
12/24/21 08:13 PM
12/24/21 08:13 PM
florida dade
cesar perez Offline OP
florida dade
Does any one run tubed on 15x3.5 wheels
Re: Tubes [Re: cesar perez] #2998285
12/24/21 09:50 PM
12/24/21 09:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Would those be front tires? You can get smaller tubes like that at farm stores and motorcycle shops.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Tubes [Re: cesar perez] #2998309
12/25/21 01:36 AM
12/25/21 01:36 AM
PA
Scully Offline
Scully  Offline
PA
Originally Posted by cesar perez
Doe[align:right][/align]s any one run tubed on 15x3.5 wheels
Yes, and it could save your life.
Re: Tubes [Re: cesar perez] #2998310
12/25/21 02:27 AM
12/25/21 02:27 AM
I use to on some old leaky cast aluminum wheels down, I wouldn't do that now due to the extra weight: down:
Make sure if you do use tubes that you are using the correct tube type for that tire, bias tube for bias ply tires, radial tubes for radial tires twocents
Re: Tubes [Re: Cab_Burge] #2998336
12/25/21 10:19 AM
12/25/21 10:19 AM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I'm using them on my early skinny Ansen wheels that didn't come with the inner safety bead hump that any modern wheel was made with. I was concerned of mass inflation loss after a wheelie or abrupt turns under power. There are a few choices out there. If I can dig up my receipt I will post the vender name here. Merry Christmas All!! Bill
Re: Tubes [Re: lancer493] #2998347
12/25/21 11:28 AM
12/25/21 11:28 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Had tubes in the fronts on my Super Tricks - car came that way.
I didn't run then with the Flys, though.
The extra weight wasn't an issue - the car ran downtrack on its rear bumper for 300 feet before it got wheelie bars.
Re: Tubes [Re: topside] #2998526
12/26/21 01:37 AM
12/26/21 01:37 AM
florida dade
florida dade
I just bought tubed for early VW will that work?
Re: Tubes [Re: cesar perez] #2998536
12/26/21 02:31 AM
12/26/21 02:31 AM
What size and type (bias or radials?) front tires are you using, Cesar?
If bias and those tubes are for the original bias ply V.W. bug cars your good, if they are for radials and your tires are radials your good scope
Don't run bias type tubes in radials type tires tsk
